What are the operations on vector field A and how do I simplify the results?
The discussion focuses on performing operations on the vector field A, specifically calculating the divergence and curl. The divergence of the vector field A, represented as div(A\vec{v}), is derived using the formula x\frac{\partial A}{\partial x}+y\frac{\partial A}{\partial y}+x\frac{\partial A}{\partial z}+2A. The curl is calculated using the Levi-Civita tensor, resulting in curl(A\vec{v})=A(0,\;-1,\;0)+(\text{grad}A)\times\vec{v}. The discussion emphasizes the use of abstract index notation and the Einstein summation convention for clarity in vector calculus operations.
  • Understanding of vector calculus operations, specifically divergence and curl.
  • Familiarity with abstract index notation and Einstein summation convention.
  • Knowledge of Levi-Civita tensor and its properties.
  • Basic proficiency in hydrodynamics and vector fields.
  • Study the properties of the Levi-Civita tensor in vector calculus.
  • Learn about the applications of divergence and curl in fluid dynamics.
  • Explore advanced topics in vector calculus, such as Stokes' theorem and the divergence theorem.
  • Review examples of vector field operations in physics, particularly in electromagnetism.
Students and professionals in mathematics, physics, and engineering who are working with vector fields and require a deeper understanding of divergence and curl operations.
gcooke
Hello. I am stuck trying to find an understandable answer to this online:
Carry out the following operations on the vector field A reducing the results to their simplest forms:
a. (d/dx i + d/dy j + d/dz k) . (Ax i + Ay j + Ax k)
b. (d/dx i + d/dy j + d/dz k) x (Ax i + Ay j + Ax k)
I know this is a dot product and cross product thing, and I think that A should become "integral Anda" (div) but I'm not sure what to do with the curl for b.
I can't find this worked out online. Can anyone direct me to a source?
Thank you!
Graham.
The best to do when you get problems as this one, is to use the abstract index notation. your first expression is the divergence of a vectorfield, and the second one is the curl, of the same field. So I will show the problem, for an arbitrary [tex]\vec v[/tex] vector field, multiplied by some A scalar field. I will denote the differential operator as: [tex]\frac{\partial}{\partial x_j} \equiv \partial_j[/tex]. And we use the einstein summation convention. That is we sum automaticaly on double indices. So:
[tex]\text{div}(A\vec{v}=\partial_k(Av_k)=v_k\partial_k A + A\partial_k v_k =(\vec{v}\nabla)A + A \text{div}\vec{v}[/tex]
As we see the first part is the "substantive" part of the total time derivative, we use in hydrodynamics. The operator explicitly in cartesian coordinates:
[tex]\vec{v}\nabla = v_x\frac{\partial}{\partial x}+v_y\frac{\partial}{\partial y}+v_z\frac{\partial}{\partial z}[/tex]
Now in your problem: [tex]\vec{v}=(x,y,x)[/tex]. The A scalar field is not given explicitly. So we have for the divergence according to the previous:
[tex]\text{div}(A\vec{v})=x\frac{\partial A}{\partial x}+y\frac{\partial A}{\partial y}+x\frac{\partial A}{\partial z}+A\left(\frac{\partial x}{\partial x}+\frac{\partial y}{\partial y}+\frac{\partial x}{\partial z}\right)=x\frac{\partial A}{\partial x}+y\frac{\partial A}{\partial y}+x\frac{\partial A}{\partial z}+2A[/tex]
For the second part we have to calculate the curl. Using the same convention as above:
[tex](\text{curl}(A\vec{v}))_k=\epsilon_{klm}\partial_lAv_m=A\epsilon_{klm}\partial_l v_m + \epsilon_{klm}(\partial_lA)v_m=[/tex]
[tex]=(A\text{curl}\vec{v}+(\text{grad}A)\times\vec{v})_k[/tex]
Where [tex]\epsilon_{klm}[/tex] is the three indice totally antisymmetric tensor, the levi civita tensor.
So now using the given field:
[tex]\text{curl}(A\vec{v})=A(0\;,\;-1\;,\;0)+(\text{grad}A)\times\vec{v}[/tex]
And we are done.
Thank you very much Thaakisfox!
G.
  • · Replies 25 ·
