Is my derivation of circular motion equations correct?
The discussion revolves around the derivation of equations related to circular motion, specifically focusing on the relationships between linear velocity, angular velocity, and acceleration. Participants explore both uniform and non-uniform circular motion, as well as different mathematical approaches to the problem, including vector and polar coordinate methods.
  • One participant presents a derivation leading to the equations v = rω and a = ω²r, questioning the conditions under which these hold true, particularly regarding centripetal acceleration.
  • Another participant emphasizes the importance of deriving the acceleration vector in polar coordinates to show its direction, suggesting that the acceleration always points towards the center in uniform circular motion.
  • A suggestion is made to use complex numbers for a simpler derivation of circular motion equations, highlighting their effectiveness despite seeming abstract.
  • A participant expresses surprise at the utility of complex numbers in describing circular motion, noting their initial perception of them as advanced and less relevant.
  • There is a discussion about the implications of the negative sign in the acceleration vector derived from the position vector, indicating inward directionality.
  • Participants discuss the possibility of extending the derivation to non-constant angular velocity using vector representations, with some noting that the initial approach may have lost directional information.
  • One participant seeks clarification on how to apply polar coordinates in their derivation, indicating a learning progression.
Participants express differing views on the best approach to derive the equations of circular motion, with some favoring vector methods and others advocating for polar coordinates or complex numbers. There is no consensus on a single method or the implications of the derived equations, particularly regarding non-constant angular velocity.
Some participants note that their derivations are valid only under specific conditions, such as constant angular velocity, and that the treatment of non-constant angular velocity may require additional considerations.
This discussion may be useful for students and enthusiasts of physics and mathematics who are exploring the concepts of circular motion, derivations involving angular and linear velocities, and different mathematical approaches to these topics.
gangsta316
Is this derivation correct?
I managed to derive [itex]v = r \omega[/itex] and (I think) [itex]a = \omega^2 r[/itex].
I did [itex]a^2 = \ddot{x}^2 + \ddot{y}^2[/itex] to get eventually
[itex]a^2 = r^2(\dot{\theta}^4 + \ddot{\theta}^2)[/itex]. Then I said that, for uniform circular motion, the angular velocity [itex]\dot{\theta}[/itex] is a constant [itex]\omega[/itex] meaning that [itex]\ddot{\theta}[/itex] is equal to zero. So then it came to [itex]a = \omega^2 r[/itex].
But how do we know, from my derivation, that this is a centripetal acceleration toward the center? Is it because the tangential acceleration is the one I discarded and so this is the perpendicular component of acceleration? Is the formula valid where the angular velocity is not constant?
For uniform circular motion the tangential speed is constant but the direction is changing, and this directional change is always pointed towards the center of rotation. To derive the acceleration vector showing the proper direction, one must start with the position vector in polar coordinates
r = r <r> (θ) where <r> is the radial unit vector and bold letters indicate a vector. Taking the time derivative using the chain rule gives
dr/dt = v = (dr/dt) <r> + r(d<r> /d θ) (d θ /dt)
But d<r> /d θ = < θ > so,
v = (dr/dt) <r> + r(d θ /dt) < θ >
To find a, take the time derivative of v and use d< θ > /d θ = - <r> . This will give the components of a in the <r> and < θ > directions and will show the Coriolis acceleration.
gansta, are you familiar with complex numbers? If so I suggest attempting the derivation that way, using polar form. If you only care about motion in a plane it's simpler than the vector approach suggested by chris, and the desired signs and direction of the acceration term comes out nicely.
I haven't learned about complex numbers and polar co-ordinates yet. I find it interesting that complex numbers (which seem abstract and not that relevant in the real world) are good at describing circular motion. I thought they were only used in really advanced level physics.
For uniform circular motion with radius r, the position vector is given by
[itex]\mathbf{r} = r \begin{pmatrix} \cos \omega t \\ \sin \omega t \\ \end{pmatrix}[/itex]
From this we can work out the acceleration vector to be
[itex]\ddot{\mathbf{r}} = - \omega^2 \mathbf{r}[/itex]
(that r is the position vector, not the radius).
Does that negative tell us that it's toward the center? The omega doesn't make a difference because it's a scalar. I quite like this derivation because we can easily get the circular motion formulas by taking the magnitude of the velocity and acceleration vectors. Although it's only valid for constant angular velocity.
yes, the negative means inwards facing (I presume that your second equals was supposed to be a minus sign).
What you have is logically equivalent to the complex polar representation BTW.
You can do non-constant angular velocity with your plane vector representation too if you want . Just include the omega derivatives too when you differentiate.
But if we do it with vectors for non-constant angular velocity isn't it kind of the same as the way I did in the first post (take x and y separately and combine them with Pythagorean theorem)?
it looks pretty similar, but in your first post you lost the direction.
also note that you can do the non-constant radius with your vector approach pretty easily too.
I've now learned a bit about polar co-ordinates. How does it work with them?
Why don't you start with expressing your vector in polar coordinates as you've learned them, plus an attempt to take first derivatives.
  • · Replies 76 ·
  • · Replies 29 ·
  • · Replies 37 ·
