Magnitude and direction of the current in conductor
The discussion revolves around analyzing electric circuits, specifically focusing on determining the magnitude and direction of current in conductors at a junction, as well as validating answers related to circuit parameters such as resistance, current, and voltage. The original poster presents multiple circuit problems with diagrams and their corresponding answers, seeking confirmation of their correctness.
  • Exploratory, Assumption checking
  • The original poster attempts to validate their answers by explaining their reasoning and calculations related to the current and voltage in various circuit configurations. Some participants question the correctness of the chosen answers and the reasoning behind them.
There is a mix of responses, with one participant expressing agreement with the original poster's answers. However, the discussion remains open, as further confirmation or alternative perspectives have not been fully explored.
The original poster has provided specific circuit diagrams and numerical values but has not received extensive feedback or alternative interpretations from other participants, indicating a potential lack of detailed discussion on the assumptions made in their calculations.
bap902
I have a few questions on three circuits problems that I have already solved. I explained how I arrived at my answers and included diagrams. I would appreciate any help in confirming that my answers are correct. Thank you!
1. The diagram below shows electric currents in conductors that meet at junction P.
http://www.stmary.ws/physics/home/marys_java/regents/Januar14.gif
What are the magnitude and direction of the current in conductor PQ? (1) 9 A toward P (2) 9 A toward Q (3) 5 A toward P (4) 5 A toward Q
I chose choice #4, 5 A toward Q because when 3 and 4 are added you get 7. But, because of the 2 moving in the opposite direction, it takes away from the overall total of 7 leaving you with 5.
2. Which diagram below correctly shows currents traveling near junction P in an electric circuit?
http://www.stmary.ws/physics/home/marys_java/regents/June0114.gif
(1) 1 (2) 2 (3) 3 (4) 4
I chose choice #4 because that is the only one where all the arrows correctly show that that the current is traveling near junction P. The arrows indicate the direction of the current toward the junction.
3. Determine the following using the figure below:
http://img509.imageshack.us/img509/8186/circuitoh0.png
R(total)= 25 ohms
I(total)= 4 amps
V(x-->y)= 20 volts
V(y-->z)= 20 volts
V(x-->z)= 40 volts
I(5 ohm resistor)= 1.3 amps
Power(10 ohm resistor - not the parallel ones)= 160 watts
Power (15 ohm parallel resistors)=26.7 watts
I included my answers as well as how I broke down the complex circuit into a simple circuit so I could arrive at those answers using the V=IR formula and working backwards.
Anyone?
Bump.
The answers looks correct to me!
  • · Replies 18 ·
  • · Replies 31 ·
