Is Quantum Mechanics Non-Local or Can Local Models Explain the Universe?
  • Context: Graduate
  • Thread starter Thread starter The Dagda
    Interpretations Quantum
The discussion centers around the nature of quantum mechanics, specifically whether it is fundamentally non-local or if local models, including hidden variable theories, can adequately explain quantum phenomena. Participants explore various interpretations of quantum mechanics, including the Copenhagen interpretation and the Many-Worlds interpretation, while addressing the implications of entanglement and Bell's theorem.
  • Some participants argue that quantum mechanics is non-local, citing entanglement where the measurement of one particle instantaneously affects another, regardless of distance.
  • Others propose that local hidden variable theories could explain quantum phenomena, challenging the non-local interpretation.
  • One participant references Bell's theorem, which states that no local hidden variable theory can reproduce all predictions of quantum mechanics, suggesting that this supports the non-local view.
  • There is mention of the Many-Worlds interpretation (MWI) as a deterministic alternative that avoids the paradoxes associated with wavefunction collapse.
  • Some participants express skepticism about the evidence supporting MWI, questioning its experimental testability and the philosophical implications of parallel universes.
  • Concerns are raised regarding the philosophical arguments presented in favor of MWI, with some participants noting that interpretations cannot be proven experimentally.
Participants exhibit a range of views, with no consensus reached on whether quantum mechanics is non-local or if local models can suffice. The discussion reflects ongoing debates about the validity of different interpretations of quantum mechanics.
Participants acknowledge that interpretations of quantum mechanics are not experimentally provable and that they remain consistent with the mathematical framework of quantum mechanics, except for local hidden variable theories.
This discussion may be of interest to students and enthusiasts of physics, particularly those exploring the foundational aspects of quantum mechanics and the philosophical implications of its interpretations.
The Dagda
I was gassing away on another forum about how quantum mechanics was non-local and so on, and someone said he didn't believe it was, and that other interpretations with local or hidden variables were more valid, this seems converse to what I'm learning. Consider me a Student of physics with a early degree level of the maths, so please don't go too heavy. Can anyone explain why he's mistaken? It seems to me interpretations like the Copenhagen interpretation are more mainstream?
Einstein didn't like QM very much. One of the cornerstones of relativity is that all frames were created equal. It has been known since Gallileo that one object's "stopped" is another object's "moving." Einstein's relativity took it a step further and accounted for the rate of the passage of time as well. A clock in a rocket ticks slower than the watch on your wrist. But to a passenger on the rocket, it is your watch that is moving slowly. One object's "proper" time is another object's "slowed" (or "dilated") time.
The main argument for the validity of relativity is based on the speed of light. It's constant to every observer. That means if you are at rest, it moves at c. If a train moving at 80mph sees the same beam light, it will measure it's speed as c and NOT c + 80mph as should be expected by classical theory. Time slows down to compensate.
Now time slowing down seems paradoxical, but as long as nothing moves faster than c, everything's dandy. That means no information can be sent faster than c. No gravity or electric fields and especially not matter. If you can travel faster than c, suddenly you have contradicted yourself, because you can send a signal to another rocket and say "I have irrefutable evidence that YOU are the one who is slow." And the world is forced to distinguish between "at rest" and "moving."
So that's why light can't move faster than c.
The problem is that QM DOES allow things to move faster than c. But only in special ways. When you entangle two particles, they share a single quantum state. The particles can be split up physically in space. When one particle is measured, the state collapses for both particles. Suppose we have two particles in the state 1/sqrt 2 |+-> + 1/sqrt 2 |-+> That is, when you measure the particle, there is a 50% chance the first particle will be spin up and the second, spin down and a 50% chance where you get the reverse. When you measure one particle, the state collapses, and both particles have opposite spins. That means that the result of the measurement must travel to the other particle instantaneously to let it know what the result is. The only reason this kind of instantaneous influence is allowed is that the results of the measurement are random. Even though the influence is infinitely fast, there is no way to send any messages through it. Similarly, there is no way to tell using one particle to tell if the other particle has been measured yet. Flow of time is still, as far as either party can tell, entirely relative.
There is an important thought-experiment (which I'm not 100% clear on) called the Bell Theorem that deals with this issue.
Thanks that's a great answer.
I am aware of Bell's it states that:
"No physical theory of local hidden variables can ever reproduce all of the predictions of quantum mechanics."
The thought experiment is valid, the experiment shows that indeed according to probability QM is non-local.
I'm wondering why someone would try to claim hidden local variable or non local hidden are more valid? The guy is very educated but I can't understand why he believes that the Copenhagen theory that is probabilistic is wrong and it is deterministic ie wave function real, hidden variable/local instead.
I know about Einstein and the EPR paradox, but this is debunked by Bell's? So why would someone with a post doctoral education challenge that issue and how?
Bell's also implies that no experiment however non-local can transfer information faster than c. But this is slightly off track.
Check Multi-Worlds. It is the best interpretation
Once you accept multi-worlds, there are no more paradoxes.
No weird stuff like 'wavefunction collapse' etc
It is even deterministic (God does not play dice!)
You mean many worlds, yes I know about it in reading about interpretations, but it is not as favoured as CI, what evidence is there that MWI may be true? And if it is how would we show it in experiment?
God does not play dice? :smile:
But didn't Bohr say stop telling God what to do with his dice?
I googled it I must admit. :biggrin:
http://arxiv.org/abs/0704.0646v2
Dmitry67 said:
Thanks for that I read it, but I don't see how this provides evidence, it's all mathematical and light on experiment? Maybe I missed something...
Kepler Newton>classical physics>landscape plus inflation>level IV multiverse>fundamental laws.
Isn't that a set of non sequiturs?
Throughout this paper, I have tried to conform to the standard
mathematical terminology as closely as possible without obscuring
physical intuition. Unless explicitly specified, the usage is
standard. The mathematical structure definition given here differs
from the common one of e.g. [31] in two ways:
1. It allows multiple types (corresponding to the different sets
Si), much like different data types (Boolean, integer, real,
etc.) in a programming language, because this greatly simplifies
the definition of more complex structures cropping up
in physics.
2. It defines a mathematical structure by all its relations. This
means that one only needs to specify generators, a finite set
of relations that generate all others.
20 The reader preferring to start without assuming the definition
of a function can begin with Zermelo-Fraenkel set theory
alone and define relations as subsets of product sets of the type
Si1 ×Si2 ×...×Sik . Subsets are equivalent to Boolean functions:
one says that the relation R(a1, a2, ..., an) holds (and that the
Boolean function R(a1, a2, ..., an) is true) if (a1, a2, ..., an) 2 R,
false otherwise. Non-Boolean functions are definable by interpreting
a relation R as an Sik -valued function and writing
R(a1, a2, ..., an−1) = an if for any values of the first n − 1 variables,
there is one and only one value an of the last variable such
that the relation R(a1, a2, ..., an) is true.
:confused: eh?
Interpretations can not be proven experimentally (otherwise they would not be called interpretations). They are all consistent with QM (except local hidden variables and objective collapse theories)
Max just gives many arguments on the phylosophycal level.
MWI is just CI *without* wavefunction collapse. So if we can describe everything without a collapse, shouldn't the collapse be cut but the Occam'z razor?
We can not see alternative universes, but he wrotes
"The key point to remember is that parallel universes are not a theory, but a prediction of certain theories. For a theory to be falsifiable, we need not be able to observe and test all its predictions, merely at least one of them"
Then he compares parralel branches to the interiour of the black holes (we can not observe them but we speculate a lot about what is inside, so modern physics had already abandoned the falsiability)
Ah yeah, good point.
Can I point out thought that Occam's razor is not a law of science it's a suggestion. Is MWI discrete from CI, if so in what ways, and can we show that those ways are enough to make it theoretical?
Speculation on speculation?
We infer black holes by gravity and the maths, trying to say what would happen given the maths seems a bit cart <horse, before>, if you see what I mean.
I quess the most important difference between CI and MWI is that MWI is deterministic. So we have a hope to finally get TOE equations in a form TOE(fi)=0, in a pure mathematical form.
Withj the probability stuff there is an inavoidable 'blah-blah-blah' part. For example, there are 2 different interpretations of what a probability is
Regarding CI, And I forgot about the mystical role of some QM systems, called "measurement systems" magically affecting the wavefunctions... I guess this is a weirdest part of CI
It's not magical it just is. Science of course has no more regard for your problems of understanding than the Universe cares about the way you are and and how you interpret it, it just is. Perhaps we should just say shut up and speculate?
And yet Bell's say is it isn't? How now brown cow?
Deterministic equals real wave function, hidden variables, non-local and local either or.
Probabilistic equals non-local no hidden variables. There's the best definition I think.
Wait, wait.
Deterministic = complex :) valued wave function which has a REAL (physical) meaning.
But no hidden variables (except the wavefunction itself)
either? where and why?
For the pure mathematical reasons I do believe that the definition(axiomatisation) of QM *should not* include any references to the huge ensembles of the molecules called 'observers' and 'measurement devices'
Otherwise there is a bad (infinite) recursion.
You ought to define QM without any references to a 'measurement'.
(This from an amateur testing his chops) I think your question comes down to, “what’s a clear argument I can make against hidden variables?” And if your protagonist is familiar with Bell’s theorem, then he must have an argument for that. I can’t imagine what that is since the matter seams to be settled. So maybe it has something to do with the locality of those hidden variables. So I’ll mention the Bohmian interpretation, which has advantages like many worlds in that it can simplify things. It’s considered to be a hidden variable interpretation but those variables are also non-local. The Bohmian interpretation is considered to be legitimate although it’s still just an interpretation. There are other interpretations containing non-local hidden variables. (See http://en.wikipedia.org/wiki/Hidden_variable_theory" )
Correct that Occam's Razor is a suggestion... each of us can reasonably adopt - in the best scientific tradition - any of several equivalent interpretations. CI (sometimes called "shut up and calculate") is popular, Many Worlds is popular, and Bohmian Mechanics (a/k/a dBB) is popular. There are more, there is the Cramer's (I think) Transactional Interpretation, Relational Interpretation, and one I think has merit (at least enough to look at) called Time Symmetric QM.
Pick one from column A, two from column B... it's really a matter of personal preference although some insist that one interpretation's virtues are greater than another's.
Sorry I was confused a little bit
Correct, MWI contains non-local hidden variables - but only for an observer (called 'frog's view')
In the 'bird's view' (the view of God, where we observe all branches of reality) there are no hidden variables.
Is it like the Transactional interpretation?
In the Time Symmetric view, the future can influence the present/past. Relativity is retained, realism is dropped. So a future measurement context influences the present, and this provides a mechanical explanation that is intended to remove the time asymmetry implied by wave function collapse.
I'm not selling this baby, too new to see all of the ramifications yet, but I think it is promising. I also think it is an intuitive way to visualize what happens. There may be similarities to TI, I will have to look at it again.
How would you do that?
I Googled interpretations, there are loads of them?
Do what? Define QM without a measurement?
take MWI. It is just an evolution of wavefunction.
It doesnot matter if there are any observers/measurement.
Only if you need to know what would be observed, then you calcalate the probability of the correlations of an observer states
But then it's not science it's just philosophy surely like the question of God?
Also in science a theory has to distinguish itself or it remains a hypothesis.
Yes, yes... But I think the very last step to TOE can not be 100% scientific, I am afraid.
When we approach it we make sacrifices on every step: we give up eucledian space, we give up flat space, we give up realism in QM. On every step science gains a lot, but there is always high price to pay, and each time this price is higher and higher.
I doubt the superstring/TOE theory will be just new formulas in the 10,11 or 26 dimensional space. I think the reason why we still don't have a final theory is that all these M-theories do not suggest any sacrifices... Something which makes all people say "oh, no, this is really crazy, I can not believe, something is definitely wrong here... I can believe in non-realism or curved spaces, but not this!"
No. This is not what QM says. You must treat the wave function the way you would treat a classical probability distribution function. It is not the state of the particle but a representation of knowledge about the particle.
(with this interpretation) then of course when the particle is measured our knowledge collapses to the updated distribution. The collapse happens on paper not in the wide world.
We measure the particle not its wave-function.
Not so. No FTL causality is necessary to explain the predictions of QM, not even the unobservable FTL causality...
The experiment is the Einstein-Podolsky-Rosen experiment (and paradox). Bell's theorem is what is violated in EPR experiments.
It is not what QM says.
It is what CI says :)
And of course CI is only an interpretation which you are free to accept or decline as you choose.
It has evidential backing though, which is why it is the mainstream interpretation, n'est pas?
Are you suggesting we throw the baby out with the bathwater?
Historical reasons...
It is the oldest one so it is used in many popular books
  • · Replies 47 ·
  • · Replies 23 ·
  • · Replies 23 ·
  • · Replies 17 ·
