Pls help me with my Resistivity Question in pHysics due tomorrow morning.
This discussion focuses on calculating the resistance and properties of copper and iron wires under various conditions. Key problems include determining the length of a copper wire with a specified resistance of 5.0Ω, calculating the minimum diameter of copper wire to limit voltage drop to 2% for a motor drawing 10 A from a 240-V source, and finding the potential difference in a copper wire carrying 12 A over a distance of 100m. Additionally, it addresses the temperature coefficient of resistivity for an iron wire, with resistance values given at different temperatures.
  • Understanding of Ohm's Law and resistance calculations
  • Familiarity with the properties of copper and iron conductors
  • Knowledge of temperature coefficients of resistivity
  • Basic electrical circuit concepts, including voltage drop calculations
  • Research the formula for calculating resistance in wires based on length and cross-sectional area
  • Learn about the temperature dependence of resistivity in materials
  • Explore voltage drop calculations in electrical circuits
  • Investigate the properties of different materials used in electrical wiring
Students studying physics, electrical engineering students, and anyone involved in electrical circuit design or analysis.
emjez15
Pls help me..thanks
17. How long should a copper wire 20 mills in diameter be for it to have a resistance of 5.0Ω?
20. An electric motor draw 10 A from a 240-V source 120 ft away. What is the minimum diameter of the copper wire in mills if the voltage drop is not to exceed 2%?
22. A copper wire 1.0 mm in diameter carries a current of 12 A. Find the potential difference between two points in the wire that are 100m apart.
24. The resistance of a copper wire is 100 Ω @ 20oC. Find its resistance at 0oC and at 80oC
25. An iron wire has a resistance of 2.00 Ω at 0oC and a resistance of 2.46 Ω at 45oC. Find the temperature coefficient of resistivity of the wire
What is it you don't understand?
You need to show some effort and identify where you are stuck.
