How Thick Would an Infinite Plate Need to Be to Mimic Earth's Gravity?
  • Thread starter Thread starter quantize
    Earth Flat
The discussion centers on calculating the thickness (H) of an infinite plate that would produce gravitational acceleration equivalent to that on Earth's surface. Using Gauss's Law for gravitation, the user initially attempted to derive H but faced challenges. Ultimately, the correct solution was determined to be H = (2/3) * R(Earth), where R(Earth) is the radius of Earth, approximately 6370 km. This conclusion was reached by equating the gravitational integrals of both models and applying density relationships.
  • Understanding of Gauss's Law for gravitation
  • Familiarity with gravitational acceleration and its calculation
  • Basic knowledge of integrals and substitutions in physics
  • Concept of uniform density in physical models
  • Study the application of Gauss's Law in gravitational fields
  • Explore the concept of gravitational fields produced by infinite planes
  • Investigate the implications of uniform density in celestial models
  • Learn about the derivation of gravitational acceleration from mass distributions
Students of physics, particularly those studying gravitation, astrophysics enthusiasts, and educators looking to deepen their understanding of gravitational models and their applications.
quantize
Imagine the Earth is indeed not a sphere of radius r, but an infinite plate of thickness H. What value of H is needed to allow the same gravitational acceleration to be experiences as on the surface of the actual Earth? (Assume the Earth's density is uniform and equal in the two models.)
r Earth = 6370km
g = 9.81 N/kg
m Earth = 5.91 * 10^24 kg
Gauss's Law?
So far I have tried to set up gauss's law(for gravitation instead) as Integral(g dot dA) for the spherical earth, and set it equal to the Integral(g dot dA) of a infinite plate version of earth. I get h = r * sqrt(2pi), which is not correct.
Can anyone tell me if I am in the general correct direction with my idea to use gauss's law for gravitational fields? My main trouble is the thickness of an infinite plate. How is this possible, in class we only learned about infinite plates w/o thickness, and parallel plates. Is this a special version of parallel plates, and if so, how does one bring H into the equation?
Can you just use Newton's Law of gravitation? Basically, you can write the Earth's mass in terms of the thickness, then equate the two equations, solving for t?
Okay, so I figured it out and no longer need help.
What I did was find the integral(g dot dA) of the spherical earth, which was 4piGm, and set that equal to the integral(g dot dA) of the infinite plate earth. Evaluating the integral, and doing some tricky substitutions with p = m/v, I found that the H(thickness) = 2/3 R(earth)
15K
