Thread Closed
Aharonov bohm effect
Share Thread
Jan26-09, 07:56 AM   #1
I am confussed with aharonov bohm effect. i read the wikipedia article.
http://en.wikipedia.org/wiki/Aharonov-Bohm_effect
The most commonly described case, sometimes called the Aharonov–Bohm solenoid effect, is when the wave function of a charged particle passing around a long solenoid experiences a phase shift as a result of the enclosed magnetic field, despite the magnetic field being zero in the region through which the particle passes.
it says "enclosed magnetic field" but "magnetic field is zero"
An electric Aharonov–Bohm phenomenon was also predicted, in which a charged particle is affected by regions with different electrical potentials but zero electric field, and this has also seen experimental confirmation
It says "different electric potentials" but "electric field is zero"
PhysOrg.com physics news on PhysOrg.com
>> Cheap, color, holographic video: Better holographic video displays
>> First entanglement between light and optical atomic coherence
>> EUROnu project recommends building Neutrino Factory
Jan26-09, 08:14 AM   #2
Mentor
"enclosed magnetic field" means the field inside the solenoid. The field is zero outside the solenoid.
The electric field is zero when the electric potential is uniform (does not vary with position). In the second case, there are two regions, each with uniform (but different) electric potential. For example, one region might have a uniform potential of 5 volts, and the other one might have a potential of 10 volts. The electric field is zero in both regions.
Jan26-09, 09:41 AM   #3
Quote by jtbell View Post
Even before placing placing the solenoid the magnetic field is zero. After the placing the solenoid also magnetic field is zero.Then, why there is phase shift?
Jan26-09, 09:52 AM   #4
Recognitions:
Quote by spidey View Post
There is a magnetic vector potential A around the solenoid which goes with 1/r.
The magnetic field B is the curl of this field and happens to be zero. The phase
shift depends on the vector potential A (not the magnetic field B)
http://www.physics-quest.org/Book_Lo...ein_Gordon.pdf
see section 11.2
Regards, Hans
Thread Closed
Similar discussions for: Aharonov bohm effect
Thread Forum Replies
Aharonov-Bohm effect Quantum Physics 2
Bohm Aharonov effect. Quantum Physics 1
Aharonov Bohm effect Quantum Physics 2
Aharonov-Bohm Effect? General Physics 1
aharonov-bohm General Physics 1
