Algorithm for prime factorization
The discussion revolves around an algorithm for finding the prime factorization of a number n. Participants explore the properties of prime numbers and the implications of the fundamental theorem of arithmetic in the context of factorization.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the reasoning behind why the first divisor d must be prime and question the implications of the fundamental theorem of arithmetic. There are attempts to clarify the conditions under which a factorization can be improved and the significance of square roots in the factorization process.
The conversation is ongoing, with participants providing insights and corrections to each other's understanding. Some guidance has been offered regarding the necessity of considering divisors up to the square root of n, and there is an exploration of the implications of prime factors in the algorithm.
Participants are working within the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is an emphasis on understanding the underlying principles rather than simply applying algorithms.
saadsarfraz
One algorithm for finding the prime factorization of a number n is the following: Starting with d = 2, and continuing until n[tex]\geq[/tex]d, try to divide n by d. If n/d, then record d as a (prime) factor and replace n by n/d; otherwise replace d by d + 1.
a) When d is recorded, how do we know that d is prime?
b) Suppose n = ab. Show that a[tex]^{2}[/tex][tex]\leq[/tex]n or b[tex]^{2}[/tex][tex]\leq[/tex]n
c)Use this fact to improve the algorithm.
see above
for part a, since we are dividing by a prime number that is how we know that d is prime. I don't know how to do part b but, i think it might have something to do with a/p or b/p, where p is the prime number.
I think you mean replace n by n/d. But if you are starting with d=2 and dividing n by d, then incrementing d and trying again, for the FIRST value of d that divides n, d MUST be prime. Can you say why?
i corrected the error. I'm still unsure about this but the fundamental theorem of arithmetic states that every natural number greater than 1 can be written as a unique product of prime numbers, since d is the first number we are dividing it by, therefore it must be prime.
That's not super clear. But if d isn't prime then it's divisible by another number. Say e. And e<d. What does that mean in terms of the algorithm?
One way to handle the factorization is to divide only by prime numbers. I made a factorization program a few years ago. I used the Sieve of Eratosthenes process to find a list of primes, and then I performed a succession of divisions up to a certain value (square root of something,... forgot the exact reason for this).
the only number less than d would be 1 then but the fundamental theorem of arithmetic says that it should be greater than 1, so the next prime number is 2.
You still don't get it. If you start from 2 and divide n by successive integers, the first d that divides n MUST be prime, otherwise you would have divided n with another integer before you hit d. Right? Right? Right? Don't just quote abstractions, think about it.
so if i take n=32 for example then 32/4=8, and 8/4=2, 2/2=1. got it. btw I'm also having some trouble doing part c).
It's what symbolpoint said. If you don't find a divisor before you hit sqrt(n), you may as well quit. You aren't going to find one. Why?
is it because the n/d would no longer be divisible by d, if a<=sqrt(n) or b<=sqrt(n) then can it be that ab<n? I donr really know how to answer this.
If n=a*b, that's a factorization of n. If both factors were greater than sqrt(n) then a*b>n. That can't be since a*b=n. So at least one of factors a or b must be less than sqrt(n).
so if the number which is greater than square root of n is not divisible by d then, there are no prime factors for that n?
No. If n has divisors, then at least one of them must be less than or equal to sqrt(n).
