How Does Tension Vary Along a Heavy Rope with Applied Force?
  • Thread starter Thread starter spacecadette
    Blocks Tension
The discussion revolves around understanding how tension varies along a heavy rope that connects two blocks, with an applied upward force. The problem involves concepts from dynamics, specifically Newton's laws, and the effects of mass on tension in a rope.
  • Participants explore how to calculate tension at different points along the rope, questioning the forces acting on the rope and the application of Newton's second law. There are discussions about treating sections of the rope as separate entities to analyze forces.
Some participants have offered guidance on using Newton's second law to analyze the system, while others express confusion about how to apply these concepts to find tension at various points. There is acknowledgment of the complexity added by the rope's mass, and participants are actively seeking clarification on their reasoning.
Participants mention specific values such as the mass of the rope and the applied force, indicating that the problem may involve numerical calculations. There is a reference to a figure that is not visible in the discussion, which may contain important contextual information.
spacecadette
The two blocks in the figure (Intro 1 figure) are connected by a heavy uniform rope with a mass of 4.00 kg . An upward force of 200N is applied as shown.
(See attachment)
I figured out the acceleration to be 3.53m/s^2
The tension at the top of the heavy rope is 120N.
How would I find the tension at the midpoint of the rope?
At the midpoint what are the forces pulling down?
good ol' Newton's second law
Hi spacecadette! :smile:
You mean the rope between the two blocks?
You have the acceleration, so just use good ol' Newton's second law on the lower block. :wink:
The rope has mass too...
oops!
oops … didn't spot that :redface:
in that case, it's Newton's second law on the lower block and half the lower rope!
Thanks, Carid! :smile:
Can someone please help me with this problem. I don't understand how to get the tension at different points in the rope. I got the acceleration easily. But I don't know how to do the other 2 parts of the problem.
Hi batmankid! :smile:
Are you the same person as spacecadette?
To get the tension part-way along a rope, just spit the rope into two ropes, each with its own mass, and use Newton's second law (or a force-diagram) on one bit of the rope. :wink:
No, I'm not the same person as spacecadette. He was able to figure out that the tension at the top of the rope is 120N. I wasn't able to get that far. Hopefully once i know how to get that, I'll know how to get the tension mid-way along the rope.
ok then … to get the acceleration, treat the two blocks and the rope between them as one body, and apply Newton's second law to it.
then to get the tension at the top of the rope, treat the lower block and the rope as one body, and apply Newton's second law to that. :smile:
I got the weight of both the lower block and the entire heavy rope, but that did not give me the tension. (4kg + 5kg)(9.8)=88.2N but that's not the 120N I'm supposed to get. What am I doing wrong?
Nevermind thanks. I figured it out!
  • · Replies 38 ·
  • · Replies 25 ·
