Electromagnetics Problem: Surface Integral of A(z) over a Hemispherical Surface
  • Thread starter Thread starter Firefox123
    Electromagnetics
The discussion revolves around an electromagnetics problem involving the surface integral of a vector field A(z) over a hemispherical surface. The original poster, an electrical engineer, is attempting to solve a problem from a textbook and is facing challenges with the setup and calculations related to the integral.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the use of Gauss' theorem and the direct calculation of the surface integral. There are questions about the correct expressions for the differential surface element and the vector field in spherical coordinates. Some participants also explore the relationship between the flux through the hemispherical surface and its base.
The discussion is active, with participants providing insights and corrections regarding the area element and the setup of the integral. There is a recognition of mistakes made by the original poster, and some participants confirm their calculations align with the expected result from the textbook.
The original poster notes constraints due to limited resources while serving in the Army Reserve, which may affect their ability to verify their understanding and calculations. There is an emphasis on practicing the conversion of vector fields and surface integrals in spherical coordinates.
Firefox123
Electromagnetics problem...
Hello. I am an electrical engineer who is trying to improve my skills in several areas, one of which is electromagnetics.
I am using the book by David Cheng "Fundamentals in Engineering Electromagnetics" and doing some problems in that book.
I am having trouble with a problem in chapter 2 of that book (its problem 2-23 or 2-25 I believe)...anyway here is the problem...
***Note on my notation: I use bold to signify a vector, since I can't use an arrow on top of it. I also use the symbol "*" for the vector dot product***
Given a vector A(z) z and a hemispherical surface centered at the origin with radius 3 with the flat bottom in the xy plane find...
The surface integral of A(z) * ds.
I have tried it several ways and can't seem to get the answer...Maybe I am writing out the differential surface element incorrectly or my spherical expression for A(z) is wrong.
If someone could give me a worked out solution I would greatly appreciate it. I normally would not go on the internet for a solution, but I am an Army Reservist currently serving in Kuwait...so my resources for such things are somewhat limited.
Thanks in advance for any help.
Russ
Hi, welcome to PF!
If you are familiar with the LATEX formatting system, this is available at PF;
check out the thread:
https://www.physicsforums.com/showthread.php?t=8997
As to your problem, have you tried using Gauss' theorem?
Let [tex]\mathcal{S}[/tex] be the closed surface around volume [tex]\mathcal{V}[/tex] consisting of the hemisphere [tex]\mathcal{H}[/tex] and the disk [tex]\mathcal{D}[/tex] in the xy-plane (i.e., z=0).
Then we have, by Gauss'theorem:
[tex]\int_{\mathcal{S}}\vec{A}\cdot{d}\vec{S}=\int_{\mathcal{V}}\nabla\cdot\vec{A}dV[/tex]
or, rearranging a bit:
[tex]\int_{\mathcal{H}}\vec{A}\cdot{d}\vec{S}=\int_{\mathcal{V}}\nabla\cdot\vec{A}dV-\int_{\mathcal{D}}\vec{A}\cdot{d}\vec{S}[/tex]
arildno said:
Hi, welcome to PF!
Hey arildno...
First of all thanks for the welcome :smile:
I am not familiar with LATEX but I will check it out...thanks for the link.
As to the problem...I have not used Gauss' theorem because at this point in the problem I don't think the text is looking for that.
I believe the point of the problem is to solve [tex]\int_{\mathcal{S}}\vec{A}\cdot{d}\vec{S}[/tex] directly so that one can get practise writing out the differential surface element.
Since they gave me the vector in cartesian coordinates [tex]\vec{A}=\vec{a_z}z[/tex]I am assuming they also want me to practise converting this to spherical coordinates.
I believe after that I have to find [tex]\vec{\nabla} \cdot \vec{A}[/tex], but that seems trivial since I end up taking the partial derivative of z with respect to z and get 1.
After that I believe I have to verify the divergence theorem by finding the volume integral of the surface, with r=3, but that doesn't seem too difficult since I know what the differential volume element is in spherical coordinates.
So the main problem right now is writing out the surface integral for [tex]\int_{\mathcal{S}}\vec{A}\cdot{d}\vec{S}[/tex]...so either my limits are incorrect or the two expressions I am taking the dot product of are incorrect.
Russ
Ok, let's look at a typical representation of the hemisphere:
[tex]x=R\sin\phi\cos\theta,y=R\sin\phi\sin\theta,z=R\cos\phi[/tex]
[tex]R=3,0\leq\theta\leq{2\pi},0\leq\phi\leq\frac{\pi}{2}[/tex]
[tex]\vec{n}=\vec{i}_{r}=\sin\phi(\cos\theta\vec{i}+\sin\theta\vec{j})+\cos\phi\vec{k}[/tex]
[tex]dS=R^{2}\sin\phi[/tex]
Did this clarify anything?
Oh dear, the area element should of course be:
[tex]dS=R^{2}\sin\phi{d}\theta{d}\phi[/tex]
I'm not sure, but aren't you simply asked to find the flux of whatever [tex]\vec{A}[/tex] represents through the hemispherical surface? And in that case, isn't the flux of [tex]\vec{A}[/tex] through the base of the hemisphere equal to the flux through the upper surface? This would lead to:
[tex]\phi _A = \vec{A}\cdot{\vec{B}} = A\pi R^2[/tex]
Where [tex]\vec{B}[/tex] represents the base of the hemisphere, and R is its radius.
That would be true if the [tex]\nabla\cdot\vec{A}=0[/tex] in the interior, by the divergence theorem.
Since you corrected the area element...
We are in agreement. I am getting the same expressions that you listed, yet when I take the surface integral of the dot product my answer comes out incorrect.
So I guess my first question should be...what are you getting for
[tex]\vec{A}\cdot{d}\vec{S}[/tex] ?
***By the way...the book has the answer as (2*pi*R^3)/3
I tried using Latex to represent the fraction but I kept on screwing it up so I think I need a bit more practise :-p
Russ
I'm also getting [tex]\frac{2\pi{R}^{3}}{3}[/tex] (:-p)
We have:
[tex]\vec{A}\cdot{d}\vec{S}=R\cos\phi\vec{k}\cdot\vec{i}_{r}R^{2}\sin\phi{d\phi}{d\theta}[/tex]
[tex]=R^{3}\cos^{2}\phi\sin\phi{d}\phi{d}\theta[/tex]
Integrating:
[tex]\int_{0}^{\frac{\pi}{2}}\int_{0}^{2\pi}\vec{A}\cdot{d}\vec{S}=2\pi{R}^{3}\int_{0}^{\frac{\pi}{2}}\cos^{2}\phi\sin\phi{d\phi}[/tex]
[tex]=2\pi{R}^{3}(-\frac{1}{3}\cos^{3}\phi)\mid_{0}^{\frac{\pi}{2}}=\frac{2\pi{R}^{3}}{3}[/tex]
We have:
Integrating:
Thanks man. I see the mistake I made...I looked over my work and I never combined two things I had written down on separate pages. Let me explain my method of doing the problem (Ill point out the part I screwed up)
The differential area vector for the hemispherical surface is in the [tex]\vec{a_r}[/tex] direction and is given by...
[tex]dS={R}^{2}\sin\phi{d}\theta{d}\phi\vec{a_r}[/tex]
And we can rewrite the vector [tex]\vec{A}=\vec{a_z}z[/tex] as:
[tex]\vec{A}=R\cos(\phi)\vec{a}_{z}[/tex]
since we know that [tex]z=R\cos(\phi)[/tex]
So know we have :[tex]\vec{A}\cdot{d}\vec{S}=R\cos(\phi)\vec{a}_{z}\cdot {R}^{2}\sin\phi{d}\phi{d\theta}\vec{a}_{r}[/tex]
And since the dot product of the direction vectors [tex]\vec{a_z}\cdot\vec{a_r}=cos\theta[/tex]
We get the expression for the dot product you have above. I was forgetting to include the dot product for the two direction vectors (even though I wrote the damn thing down on another page) and so I was missing a cosine.
LOL I feel like an idiot...but anyway... thanks for your time. Sorry to bother you guys with something so trivial.
Sometimes I just make dumb mistakes and I don't catch them. *sigh*
Thanks again.
Russ
No problem :smile:
One more question...related to Latex...
as:[tex]\vec{A}=\{R}cos\theta\vec{a_z}[/tex]
That should read "R cos (theta)"... with no bracket
and also this part...
steadele said:
since we know that
[tex]\{Z}={R}\cos\theta[/tex]
That should read "z=R cos (theta)"...with no bracket
And finally...
steadele said:
So know we have :
[tex]\vec{A}\cdot{d}\vec{S}=\R\cos\theta\vec{a_z}\cdot\ {R}^{2}\sin\phi{d}\theta{d}\phi\vec{a_r}[/tex]
There should be an "R" before the cosine and no bracket before the R^2..
How do I edit the code to fix these so my post is correct?
Thanks.
Russ
First of all, you should use [tex]\phi[/tex] rather than [tex]\theta[/tex] in order to have a consistent notation:
[tex]\vec{A}\cdot{d}\vec{S}=R\cos(\phi)\vec{a}_{z}\cdot{R}^{2}\sin\phi{d}\phi{d\theta}\vec{a}_{r}[/tex]
Click on the LATEX graphics to reveal the code
True...I noticed that also. I think sometimes there is a difference between the way that engineering books and physics books define the angles.
Ah. Thanks. Ill try to edit the post and make corrections.
Russ
I know, but it is not primarily a difference between physics and engineering books, but 2 "schools" of thought.
Personally, I abhor using the alternate convention of [tex]\phi,\theta[/tex]
The reason for my disgust of this practice, is that it is inconsistent with the dominant convention for representing 2-D polar coordinates.
There, almost without exception, people use [tex]\theta[/tex] as the symbol for the angle.
Why should we suddenly redefine the planar angle into [tex]\phi[/tex] when we take the step into 3-D??
To me, this move seems completely unmotivated and fundementally unpedagogical.
Sounds like you have strong feelings about this issue...
:rolleyes: please don't hurt me...
Hmmmm...a friend of mine who was a math/cs major has similar complaints about the engineers notation of spherical coordinates.
I could see where having two different notations could be somewhat confusing indeed. Why don't engineers and mathematicians/physists use the same notation? Why the difference?
Russ
I think it is an example of the inertia of tradition
Somewhat similarly, I think it is an unnecessary complication that divers practitioners have not yet agreed upon adhering to a single system of units of measure.
That unit systems other than SI units are still in use, is in my opinion deplorable.
It cannot be doubted, that a unit system based on the decimal position system is more efficient.
Why should we suddenly, when doing physics, change the "natural" units appearing in maths?
Why should, for example a quantity of 12 base units be a new unit, rather than letting a quantity of 10 base units correspond to a new unit?
For example, when learning maths and units, why should kids be given the additional burden of making (for them) non-trivial conversions after their main computational work?
If for example they are to add together the lengths of 7 rods, each with lengths 4.8 inches, the will have to rearrange their answers into groups of twelves, to find the number of feet, and so on
(Isn't it 12 inches to a foot? I never liked those conversions..)
help! does anyone have access to Hayt and Buck's solutions manual to Engineering Electromagnetics 6/E? my classmates and i are really faring badly... for anyone who has access to this text's solutions manual, please e-mail me at bluspels_and_flalanspheres@yahoo.com... thanks in advance.
  • · Replies 16 ·
