Is My Metal Sample a Conductor or Semiconductor? Discover with This Experiment
The discussion revolves around determining whether a given metal sample is a conductor or a semiconductor through experimental methods. Participants explore various approaches and clarify concepts related to the nature of the material.
  • Exploratory, Technical explanation, Debate/contested
  • One participant requests an experimental setup to identify the nature of the metal sample.
  • Another participant makes a humorous remark questioning if the metal is related to a specific band, which is not taken seriously by others.
  • A participant expresses uncertainty about whether a semiconductor can be classified as a metal, suggesting the term "wire" might be more appropriate.
  • One participant proposes a test involving temperature and resistance, noting that conductors typically show increased resistance with rising temperature, while semiconductors may show decreased resistance depending on purity.
  • A later reply acknowledges the proposed test as the desired answer.
There is no consensus on the classification of the material as a conductor or semiconductor, and multiple viewpoints regarding the terminology and experimental approaches remain. The discussion includes both technical insights and humorous exchanges.
Participants express varying assumptions about the definitions of "metal" and "semiconductor," and the discussion does not resolve the implications of these definitions on the experimental setup.
mabs239
You are given a piece of metal of one square cm area and 10cm long. You do not know whether it is a conductor or a semiconductor. Devise some experimental setup to know the nature of the material.
Is it George Metal, conductor of the Northern South Jersey Philharmonic Pick-up Band?
Jimmy thanks for answer,
But what is the experimental setup? I am sorry for not picking up your joke. I think its a joke.
I am not sure if a semiconductor could be called a metal. The word "metal" in first statement can be replaced by "wire".
Semiconductors are sometimes referred to as semimetals.One test you can try is to see how the resistance changes with temperature.with conductors the resistance increases with temperature with semiconductors(depending on its purity)the resistance decreases with temperature.
Hello Dadface,
Your's is the answer I was looking for.
Very Good
  • · Replies 0 ·
10K
  • · Replies 27 ·
