Reduce to x+iy: Solving for z=cos\theta+isin\theta
  • Thread starter Thread starter kathrynag
The problem involves reducing the expression \(\frac{1+z}{1-z}\) to the form \(x+iy\) where \(z\) is defined as \(z=\cos\theta+i\sin\theta\). The context is complex numbers and their manipulation.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the approach of multiplying by the conjugate to simplify the expression. There is a question about whether the correct conjugate has been used, with suggestions to consider the conjugate of \(1-z\) instead of \(1+z\).
The discussion is ongoing, with participants questioning the initial steps taken in the solution process. Some guidance has been offered regarding the correct conjugate to use, but no consensus has been reached on the next steps.
There is a focus on ensuring the correct application of complex conjugates, and participants are clarifying the definitions and forms of the expressions involved.
kathrynag
Reduce to x+iy
[tex]\frac{1+z}{1-z}[/tex] where z=cos[tex]\theta[/tex]+isin[tex]\theta[/tex].
Multiply by conjugate
[tex]\frac{1+2z+z^{2}}{1-z^{2}}[/tex]
When I plug in the z value nothing seems to cancel out.
You seem to have multiplied both the numerator and denominator by [itex](1+z)[/itex]...but that isn't really the complex conjugate of [itex](1-z)[/itex] is it?:wink:...Don't you actually want to multiply by [itex](1-\bar{z})[/itex] instead?
So i should multiply by 1+(costheta+isintheta)?
No, [itex]1-z=(1-\cos\theta)-i\sin\theta[/itex], so [itex]\overline{1-z}=[/itex]___?
  • · Replies 17 ·
