Projectile motion (magnitude and direction)
The problem involves projectile motion, specifically determining the magnitude and direction of a projectile's velocity after a certain time interval, given its initial speed and launch angle.
  • Exploratory, Mathematical reasoning
  • Participants discuss calculating the vertical and horizontal components of velocity after 4 seconds, with some expressing uncertainty about the process.
Some participants have provided guidance on using kinematic equations to find the final velocities, while others are still seeking clarification on the steps involved. There appears to be a productive exchange of ideas, with at least one participant indicating understanding after the discussion.
Participants are working within the constraints of a homework assignment, which may limit the amount of direct assistance they can receive.
blazeuofa
A projectile is fired at a speed of 45 m/s at an angle of 40 degrees above horizontal. Determine the magnitude and direction of its velocity 4 seconds later.
ax=0 ay=-g
find the vy and the vx after 4 seconds and find the resultant vector.
yeah i don't get how to do that though
oh hahah ok well
Given: vi= 45 m/s and t = 4
so vyi = sin (40) vi and vxi = cos (40) vi
and to find the speed in four seconds you use the kinematics equation
vyf = vyi + (ay) (t) and velocity in the horizontal remains constant since ax = 0
find those to values and vf = sqrt ( vyf^2 + vxf ^2)
Do you understand it? if not I'll try to explain it a bit more
yeah i got it thanks
  • · Replies 18 ·
28K
