Force exerted by an external electric field
The problem involves a particle with mass and charge moving in an electric field, requiring the determination of the time it takes for the particle to come to a complete stop under the influence of the electric force. The subject area includes dynamics and kinematics within the context of electric fields.
  • Mixed
  • Participants discuss the appropriate equations to use, considering both kinematics and dynamics. There are attempts to apply the equations of motion, and questions arise regarding the correct acceleration and the interpretation of the force due to the electric field.
The discussion is ongoing, with various approaches being explored. Some participants have provided calculations and corrections, while others have raised questions about the arithmetic and the assumptions regarding acceleration. There is no explicit consensus on the final answer, but guidance has been offered regarding the use of relevant equations.
Participants note the importance of correctly interpreting the charge unit (millicoulombs) and the implications of the electric field's direction on the particle's acceleration. There is also mention of potential arithmetic errors affecting the final results.
lacar213
A particle of mass 1.20 kg with a charge of +2.30 mC is shot into a region with an electric field of strength 18.0 N/C, having a direction opposite the particle's velocity. If the particle has an initial speed of 2.40 m/s, how long does it take to come to a complete (though momentary) standstill? Assume there are no other forces acting on the particle.
F = qE
F= ma
I'm not sure what equation to start with because of all the information already given. I couldn't find any equations dealing with time in the chapter this problem was in. It sounds like you may have to use kinematics but I'm not sure if that is the correct way to do it.
Kinematics (well dynamics really) sounds good to me. What do you think the first step would be?
Vf = Vi +at ??
lacar213 said:
Vf = Vi +at ??
Looks good to me.
0 = 2.40 + 9.8 (t)
t = 9.8 / 2.4 = 4.08333
lacar213 said:
0 = 2.40 + 9.8 (t)
Why have you used an acceleration of 9.8 m.s-2?
I forgot to find the force using F=qe then you can plug it into f=ma
A = .000035
.000035t = 2.40 - 0
t = .000014
would the acceleration be negative also since the field of strength is opposite the particle
the problem states millicoulombs not micro - t = .014375
A = .000035
.000035t = 2.40 - 0
You're good up until this point. However, your final answer is wrong.
lacar213 said:
t = .000014
You may want to check your arithmetric
Yes, but you took care of that (be it intentionally or otherwise) in your second line above, by multiplying through by -1.
Your final answer is still wrong. Recheck your basic arithmetic. Notice that you are dividing a number greater than one by a number smaller than one. How can the result be less than one?
2.4 / .0345 = 69.5652
You're getting closer, but your acceleration is two orders of magnitude out.
GOT IT thanks for the help!
Not a problem :smile:
