Testing Wood for Lead: Help Finding an Effective Method
The discussion revolves around methods for testing wood for lead contamination, particularly in the context of historical pollution from leaded fuels. Participants explore various testing techniques, including both destructive and non-destructive methods, and express concerns about the presence of lead in wood.
  • One participant expresses concern about lead contamination in wood due to historical use of leaded fuels and seeks effective testing methods.
  • Another participant inquires whether the testing should be destructive or non-destructive.
  • A participant suggests a detailed chemical method involving combustion, acid treatment, and subsequent testing of the aqueous sample for lead content.
  • One participant questions the relevance of lead in wood, arguing that wood does not accumulate heavy metals significantly and is low on the food chain, suggesting that trace amounts may not be a concern.
  • Another participant mentions that traditional methods like X-ray fluorescence and ICP-AES are typically used for such analyses but notes their expense and the availability of testing companies.
Participants express differing views on the significance of lead in wood and the appropriateness of various testing methods. There is no consensus on the necessity of testing or the best approach to take.
Participants highlight the potential limitations of certain testing methods, including the practicality and reliability of classical chemical analysis for trace amounts of lead.
Andre
Lead in the form of -for example- Tetra ethyl lead has long been used as fuel additive, ultimately causing soil pollution. There is concern that this lead ultimately settled in wood during the growing process, which may have led to unacceptable concentrations of lead in wood.
So, it would be desirable to test wood on lead contents. It appears that this is being done with hand held http://www.niton.com/Portable-XRF-Technology/how-xrf-works.aspx.
So I attempted to google for a chemical testing method of wood for lead concentrations but with underwhelming success. So my question is...help.
Chemistry news on Phys.org
Do you want to destructively test or swipe test?
anything goes, destructive is fine, thanks.
You could carefully combust a weighed sample of the wood in a covered crucible using a muffle furnace set to about 400C. Remove and cool then quantitatively transfer the ash (using DI water only) into a large beaker. Add some hydrochloric acid and boil gently until only a moist residue remains. Add some nitric acid and boil gently until only a moist residue remains.
Cool and take up the moist residue into some DI water. Dilute the water to a known volume (100 mL, for example).
Test the aqueous sample using an over the counter lead test kit for testing water samples. The amounts of nitric and hydrochloric acid you use are not too important but you should have a clear solution at the end of the process.
You should treat a blank in the same way and subtract any reading you obtain from that of your sample.
Good luck with it.
I'm not entirely sure why you think wood would be an issue. Lead is a heavy metal and tends to bioaccumulate in fatty tissues. (not something wood has a lot of) Wood is also very far down the food chain, meaning low levels in general of bioaccumulated toxins. I've never heard of it anyway.
In any case, you're talking about looking for trace amounts, in which case the 'classical' method of analysis chemistree mentioned may not be usable and/or practical and/or reliable.
X-ray fluorescence, or ICP-AES would be the typical methods used in the Real World. Both are indeed pretty expensive. That's why there are lab and testing companies.
  • · Replies 19 ·
11K
