Angular momentum of the sun and a white dwarf
The discussion revolves around the angular momentum of the Sun and its future state as a white dwarf. The problem involves calculating the current angular momentum of the Sun, its angular momentum as a white dwarf, and the time it would take for the white dwarf to complete one rotation.
  • Participants discuss the calculation of angular momentum using the moment of inertia and angular velocity. There is uncertainty regarding the new spin angular velocity of the white dwarf and its impact on angular momentum. Questions are raised about the conservation of angular momentum and what factors might change it.
Some participants have confirmed the method used for calculating the Sun's angular momentum but express uncertainty about the implications of changing the radius when considering the white dwarf. There is a recognition of the conservation principle, and one participant attempts to relate angular momentum to the rotation period of the white dwarf.
Participants are working under the assumption that the mass of the Sun remains constant during its transition to a white dwarf. There is also a mention of potential arithmetic checks that have not been performed, indicating a focus on conceptual understanding rather than final numerical accuracy.
Fendergutt
The Sun rotates about its own axis once every 26.0 days. Its mass is m_sun = 2.0E30 kg and radius is r_sun = 7.0E8 m. Assume that the Sun is a solid sphere with uniform density.
Astrophysicists predict that the Sun will collapse into a white dwarf in some billions of years. Its density will be high, and its radius 5.8E6 m. Assume the mass of the Sun to be unaltered (a good approximation for our calculation).
(i) What is the Sun's angular momentum now?
(ii) What is the Sun's angular momentum as a white dwarf?
(iii) How long will it take for the white dwarf Sun to rotate about its own axis?
I = (2/5)*m*r^2
L = Iω = Iωk (k being the z-axis unit vector)
(i)
ω_sun = (2pi)/(26 days) = 2.8E-6 rad/s
L = I_sun*ω_sun*k = (2/5)*m_sun*r_sun²*ω_sun*k = (2/5)*2.0E30 kg * (7.0E8 m)² * ω_sun * k = 1.1E42 kgm²/s
(ii)
I don't know the new spin angular velocity of the white dwarf, do I? If I leave ω_white = ω_sun the formula for L above with inserted new value for radius r_white gives appr. 7.5E37 kgm²/s k, ie. the angular momentum is lowered. Can this be correct?
(iii)
I don't know what to do here. I want to find the new period T, but I suspect there is something odd in (ii). Is there a relation I have overseen?
Thanks for any help.
Fendergutt said:
(i)
I didn't check the arithmetic, but the method is correct.
(ii)
What's required to change the angular momentum? Does that apply here?
Ah, so you are saying to me: Angular momentum is a conserved quantity: a system's angular momentum stays constant unless an external torque acts on it.
Then I set up T_white = ( I_white * 2pi * k ) / L which gives a rotation period of 1.5E2 s or 150 s.
(Mathematically: L features numbers and the unit vector k; In the calculation above I mentally ignored the unit vector because it was a feature of both nominator and denominator -- I'm I right to do this?)
All good.
  • · Replies 17 ·
18K
