Electric field at a point on a contour line
The discussion focuses on calculating the electric field at point k on a contour line, using the equation ∆V = Ed. The user attempted to set V at -5 kV and measure the distance to charge Q1 but found this approach ineffective. A key insight provided is that the electric field E can be determined by measuring the perpendicular distance from point k to the nearest contour line, with the understanding that the difference between contour lines is 1 kV. The negative sign in the equation indicates the direction of the electric field.
  • Understanding of electric fields and potential differences
  • Familiarity with contour line diagrams in electrostatics
  • Knowledge of the relationship between voltage and electric field (E = -∆V/d)
  • Basic skills in measuring distances in physics diagrams
  • Study the concept of electric field lines and their representation in contour diagrams
  • Learn how to calculate electric fields from multiple point charges
  • Explore the implications of the negative sign in electric field equations
  • Practice problems involving voltage and electric field calculations in electrostatics
Students studying electrostatics, physics educators, and anyone looking to deepen their understanding of electric fields and potential differences in electrical systems.
maxsthekat
Hi guys!
In this question I am asked to "Calculate the size of the electric field at k". See image at: http://capa-new.colorado.edu/msuphysicslib/Graphics/Gtype54/prob04a_threeqcontour.gif
Note: although the picture states "Volts", everything is actually measured in kV.
∆V = Ed
I tried to set V = -5kV, and solving for E by measuring the distance from point k to Q1, but this doesn't seem to work. Will I have to do this for all three charges? Or, am I totally off base and should be approaching it from a different angle?
Thanks for your help!
-Max
maxsthekat said:
Hi guys!
∆V = Ed
-Max
As I figure it the difference between each contour line is 1 KV. Since
[tex]E = -\frac{\Delta V}{d}[/tex]
you want to measure the perpendicular distance from k to the nearest contour line and express E as so many volts per meter (or what ever distance unit you desire). Note the minus sign in my equation. That implies something about the direction of E.
  • · Replies 68 ·
9K
  • · Replies 28 ·
