Solve Mystery of Strange Mobile Phone Issue
  • Thread starter Thread starter wolram
    Mobile Strange
The discussion centers on a recurring issue with a mobile phone that fails to turn on after charging, requiring the battery to be removed and reinserted to function. A similar problem is noted with a laptop, which locks up when the charger is reconnected while powered on. Participants suggest troubleshooting methods, including turning the devices off before charging and exploring OEM forums for specific manufacturer insights. The underlying cause may relate to grounding issues with the chargers, affecting device performance.
  • Understanding of mobile phone battery management systems
  • Knowledge of laptop power supply behavior
  • Familiarity with troubleshooting electronic device issues
  • Awareness of OEM support resources and forums
  • Investigate mobile phone battery management systems and their reset procedures
  • Learn about laptop power supply grounding issues and their effects
  • Explore troubleshooting techniques for electronic devices experiencing power issues
  • Research specific OEM forums for insights on similar device problems
Mobile phone users, laptop owners, technicians troubleshooting power-related issues, and anyone interested in understanding device charging behaviors.
wolram
Dearly Missed
I have a mobile that i only keep for emergencies, the strange thing is, it will not turn on after a recharge, i have to take the battery out and and put it back in, then it works fine
any ideas why this happens?
not sure, but i have a similar problem with my laptop computer. as long as the charger is plugged in, it's fine. if the charger becomes unplugged, it's still fine. plug the charger back in with the computer running, and the darn thing locks up. i suspect the ground on the charger may be floating up and the difference in potentials causes an error when you plug them back together, but it's just a guess.
you could play around with different scenarios like turning the phone off before you plug it into the charger, then back on after or before you unplug it.
Perhaps a call or email to them might help. Sometimes there are specific OEM forums on the net which can be very assistive if they have a website.
  • · Replies 23 ·
