Can I run my Laptop from my car's 12V DC ?
  • Thread starter Thread starter curiousOne
    12v Dc Laptop
The discussion revolves around the feasibility of running a laptop from a car's 12V DC power supply. Participants explore various methods, including the use of DC to DC adapters, inverters, and the implications of voltage requirements and power quality.
  • Product recommendation
  • Some participants question the necessity of specialized cables or adapters, suggesting that a simple cable might suffice if the voltage matches.
  • Others note that if the laptop requires more than 12V, a DC to DC converter would be necessary, or alternatively, a 110V inverter could be used with the laptop's power supply.
  • Concerns are raised about the quality of the car's 12V DC power, including potential voltage spikes and the fact that the voltage may exceed 12V when the engine is running.
  • Several participants recommend specific brands of adapters, such as Kensington and Targus, highlighting their versatility and reliability for use in various environments, including cars.
  • One participant shares a personal experience with a Targus adapter, noting its durability and efficiency, while also mentioning a past incident of damage due to improper handling.
  • Another participant discusses the general market for laptop adapters, suggesting that many manufacturers are similar and that options vary in terms of features and price.
Participants express differing views on the necessity and effectiveness of various adapters and methods for powering laptops from a car's 12V supply. There is no consensus on the best approach, and multiple competing views remain.
Participants mention the potential inefficiency of using inverters and the risk of draining the car battery when not running the engine. There are also references to the variability in laptop power requirements and the quality of power from car sources, which could affect performance.
curiousOne
Ok,
I know DELL sells these really expensive DC to DC 'adapters' that can run my laptop. I can also run it from a DC to AC converter and plug my charger into that.
But obviously, wouldn't it be simply a matter of having the right cable ?
I'm just wondering what that DELL cable really does.
Does anyone know ?
Thanks.
Computer science news on Phys.org
Depends how many DC volts your laptop needs.
If it's more than 12V you need a DC:DC converter to up the car's output to what the laptop needs. Or you can use a 110V inverter and your regular laptop power supply.
Your car's 12V DC is not a clean source.
If the engine is running, it will be 14V or more. In addition, there will be high voltage spikes, and you will need more than just a cable, even if your computer is 12V.
Kensington makes a line of laptop adapters (60 to 125 W) that have tips (most included; rarer ones available by mailing away) that step down the output voltage to the one appropriate for your laptop--some take in wall voltage, car voltage, airplane voltage or all of the above (obviously, the more bells and whistles, the more expensive):
http://us.kensington.com/html/16414.html
How's this work? There's actually very few laptop AC adapter makers out there (come to think of it, there's actually very few actual laptop manufacturers--most companies just spec parts, slap a badge on somewhere, and maybe modify the case).
EDIT: No affiliation with Kensington. Thought Belkin made something similar, but couldn't find it when I looked quickly.
If you go the adapter route, the Targus Adapaters are awesome, I've been using those for about 5 years. One came with my laptop but ended up burning a hole through the cord after being set against a heater during winter (completely my fault).
So, I went a bought another one and use it all of the time, not just in the car.
Ah yes! Those were the ones I was thinking of!
To the OP, if you get sticker shock out of this, the other alternative would be to buy a 100W(ish) car inverter (DC to AC converter) which you'd then plug your laptop into. Not terribly efficient, but handy when you need to plug something else in. Also, may run down your car battery (when the alternator isn't running).
How's this work? There's actually very few http://www.uxsight.com/category/31512/for-dell.html" makers out there (come to think of it, there's actually very few actual laptop manufacturers--most companies just spec parts, slap a badge on somewhere, and maybe modify the case).
I bought this one from a website store not long ago, you can have a look.
I think it is better
If you go the adapter route, the http://www.laptopz.com/dell-ac-adapters-c-11_30.html" are awesome, I've been using those for about 5 years. One came with my laptop but ended up burning a hole through the cord after being set against a heater during winter (completely my fault).
I will soon have a used dell laptop screen. It is interesting to see how much can be packed inside a case so small these days. thank you very much.
  • · Replies 31 ·
10K
  • · Replies 17 ·
10K
  • · Replies 68 ·
16K
