Nuclear fission produces quark mass
Nuclear fission produces quark mass through a process where the separation of particles within an up quark generates heavier quarks due to increasing force with distance. The discussion highlights that a top quark is 32 times more massive than a bottom quark, while a charm quark is 8 times more massive than a strange quark. The exponential cascade effect in quark production is linked to the properties of directional invariance, leading to the conclusion that quarks are associated with Dark Energy. The generation of quark families follows an odd power of two sequence, culminating in the fourth family represented by 2^7.
  • Understanding of nuclear fission processes
  • Knowledge of quark types and their mass relationships
  • Familiarity with particle physics concepts such as quark confinement
  • Basic grasp of geometric properties related to polyhedra
  • Research the relationship between nuclear fission and particle mass generation
  • Explore the concept of quark confinement in detail
  • Study the implications of Dark Energy in particle physics
  • Investigate Euler's formula for polyhedra and its applications in physics
Physicists, particle theorists, and students of advanced physics interested in the relationship between nuclear processes and fundamental particle mass generation.
kurious
"nuclear" fission produces quark mass
A top quark is roughly 32 times more massive than a bottom quark.
A charm quark is roughly 8 times more massive than a strange quark.
And a down quark is roughly 2 times more massive than an up quark.
In nuclear fission 2 neutrons yield 4 neutrons which become 8 neutrons
then
16 then 32 etc.
So how are quark masses produced?
If an up quark is made from two smaller particles and separating those
particles creates other quarks (quark confinement analogy)successively
heavier quarks will be created if the force holding the two particles
of the up quark together gets stronger with increasing separation.
Suppose that the space between the two particles of the up quark is
occupied by
groups of unstable particles of another kind ( analagous to unstable
atomic nuclei), and one of the particles that constitute the up quark
emits the equivalent of a neutron.An exponential cascade will be set
in motion yielding
more and more force carriers as distance increases.This is why the
force between the two particles of the up quark gets stronger with
increasing distance.
But why are the numbers 4 and 16 missing from the cascade - why are no
quarks produced at the distances corresponding to these
numbers.ANSWER:
quarks are made - and they go by the name of Dark Energy!
There are thus 4 quark families ( a missing lepton too presumably).
My answer to this is the properties of directional invariance. Imagine a cube with its 8 vertices, if one vertex is removed, the cube cease to exist. Each vertex is the intersection of three directions. If each vertex is considered as one directional property then there are eight such property for a cube to exist. These are the eight properties of directional invariance. top-right-front, top-right-back, down-right-front, down-right-back, top-left-front, top-left-back, down-left-front, down-left-back.
The generation of family seems to follow odd power of two's. [itex]2^1, 2^3, 2^5, 2^7[/itex] where [itex]2^7[/itex] is the 4th family.
If four vertices are removed from the cube then another stable configuration is formed called a tetrahedron. All stable configurations seems to satisfy Euler formula for polyhedra [itex]V - E + F = 2[/itex] where v is the number of vertices, E is the number of edges, F is the number of faces.
  • · Replies 35 ·
9K
