How to Calculate Moment of Inertia About Each Axis?
The discussion revolves around calculating the moment of inertia and the inertia tensor for a triangular shape in the z = 0 plane. Participants are exploring the concepts of inertia tensors and the necessary calculations involved in determining moments and products of inertia.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to understand how to calculate the moment of inertia about each axis and seeks clarification on the process. Some participants discuss the use of integrals for calculating moments of inertia and mention the parallel axis theorem. Others highlight the need to find both moments and products of inertia when determining the inertia tensor.
Participants are actively engaging with the problem, with some providing insights into the mathematical framework needed for the calculations. There is a recognition of the importance of both moments and products of inertia, and the discussion is exploring various interpretations of the problem setup.
There is mention of a specific triangle configuration and the requirement to find the inertia tensor with respect to the origin. The discussion also notes the use of a specific area element in the calculations, indicating constraints related to the geometry of the problem.
Luminous Blob
I have just started learning about inertia tensors and am trying to do the problem in the attached document. I'm not sure how to calculate the moment of inertia about each axis. I would appreciate it if anyone could explain to me how it is done.
OK, so I'm assuming that you have a triangle in the z = 0 plane. You can use the x, y, and z -axes. The moment of inertia about any axis is the integral of:
ρ(r) r dr
where ρ(r) is the quasi-linear mass density (mass per incremental distance away from the axis) and r is the distance from the axis. Alternatively, you can use the parallel axis theorem.
In your attachment, it is clearly stated that you are to find the inertia tensor.
Hence, it is insufficient to find the moments of inertia, you must also find the products of inertia.
I will assume henceforth, that we are to find the inertial tensor with respect to the origin.
1. Spin and inertial tensor:
Let a point particle with mass [tex]\delta{m}[/tex] have distance [tex]\vec{r}[/tex] to the origin, and let the particle's velocity be [tex]\vec{v}[/tex]
The origin is at rest, so that we have:
[tex]\vec{v}=\vec{\omega}\times\vec{r}[/tex]
Hence, the spin of the particle about the origin is given by:
[tex]\delta\vec{S}=\vec{r}\times\delta{m}\vec{v}=<br /> \vec{r}\times\delta{m}(\vec{\omega}\times\vec{r})=\delta{m}((\vec{r}\cdot\vec{r})\vec{\omega}-(\vec{r}\cdot\vec{\omega})\vec{r})[/tex]
by a common vector identity.
With index notation, we have:
[tex]\delta{S}_{i}=\delta{I}_{ij}\omega_{j},\delta{I}_{ij}=\delta{m}(r_{k}^{2}\delta_{ij}-r_{i}r_{j})[/tex]
where [tex]\delta_{ij}[/tex] is the Kronecker delta, [tex]1\leq{i,j,k}\leq3[/tex], and Einstein's summing convention has been adopted.
[tex]\delta{I}_{ij}[/tex] is the inertial tensor associated with the given particle.
Since we have a rigid body, the body's inertial tensor with respect to the origin, [tex]I_{ij}[/tex] is simply the sum of the point particles' associated
inertial tensors, i.e.,
[tex]I_{ij}=\int\delta{I}_{ij}[/tex]
Note in particular, that the diagonal elements i=j in the inertia tensor are simply the moments of inertia about the axes [tex]\vec{i}_{1},\vec{i}_{2},\vec{i}_{3}[/tex]
It is seen that the inertial tensor is symmetric; the off-diagonal elements are called products of inertia, and are, for example, important in wobbling/instability phenomena.
Calculations follow in the next post.
The figure is a triangle with vertices:
[tex]((0,0,0),(\frac{L}{2},L,0),(L,0,0))[/tex]
Any point [tex]\vec{r}[/tex] on the triangle may be written as:
[tex]\vec{r}(u,v)=((-\frac{L}{2},L,0)u+(L,0,0))v, 0\leq{u,v}\leq{1}[/tex]
Clearly, since [tex]z=r_{3}\equiv{0}[/tex], we only need to calculate:
[tex]I_{11},I_{22},I_{33},I_{21} (x=r_{1},y=r_{2})[/tex]
the particle mass satisfy [tex]\delta{m}=\rho{dA}[/tex], whereas the proper area element dA is given by:
[tex]dA=||\frac{\partial\vec{r}}{\partial{u}}\times\frac{\partial\vec{r}}{\partial{v}}||dudv[/tex]
This should give you the necessary info to solve the problem.
arildno,
Just out of curiosity, why are you calling the orbital angular momentum of a particle "spin?"
Oh dear, that's what we call it in Norwegian..
  • · Replies 28 ·
  • · Replies 40 ·
