How is Maximum Height Determined in Unsteady Fluid Flow into a Cylinder?
  • Thread starter Thread starter hem1ngway
    Flow Height
This discussion revolves around the dynamics of unsteady fluid flow into a cylinder, specifically focusing on how the maximum height of the fluid can be determined. The problem involves a cylinder with a larger diameter and a smaller hole at the bottom, prompting questions about the relationship between fluid flow and height.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the relationship between fluid height and flow rates, questioning the conditions under which the fluid level stabilizes or decreases. There are discussions about applying Bernoulli's principle to derive relationships between fluid velocity and height.
The discussion is ongoing, with participants providing insights into the flow dynamics and raising questions about the application of Bernoulli's equation. There is an exploration of different interpretations regarding the behavior of the fluid level over time.
Participants are considering the assumptions of inviscid incompressible flow and the implications of flow rates into and out of the cylinder. The problem context includes the challenge of determining the maximum height of fluid in relation to these flow rates.
hem1ngway
Hey this problem of mine involves unsteady fluid flow (Q) into a cylinder of diameter (D). There is a small hole at the bottom of the cylinder of diameter (d) which is much smaller than (D) hence d << D. Because of this the fluid level will rise to a maximum height (h) before decreasing to zero over time.
Please see diagram
http://img407.imageshack.us/img407/8462/pic1ub8.th.jpg
How does the unsteady fluid flow relate to the height? As in is it possible to work out this maximum height that would occur?
I'm so stuck on this! Could anyone point me in the right direction? I understand that the work will not be done for me but if you could point me in the right direction with equations to use I would be very greatful.
Why would the fluid level decrease to zero? The fluid level should reach a steady state when the flow rate through the smaller hole becomes equal to the flow rate into the cylinder. The velocity of the fluid issuing from the smaller hole should increase as the static pressure increases. If you assume an inviscid incompressible flow, you can derive a relationship between this velocity and the fluid height from Bernoulli's principle.
The fluid level would eventually decrease to zero over time as it would flow out of the smaller diameter at the bottom of the cylinder due to gravity.
When the flow rate into the cylinder equals the flow rate out of the cylinder a height of fluid will occur.
How do I work out that height of fluid and relate it to the flow rate into and out of the cylinder?
To find the flow rate out of the cylinder, you need to know the velocity of fluid issuing from the small hole. To do this, you will need to apply Bernoulli's equation to the fluid issuing from the smaller hole.
As you may recall, Bernoulli's equation states that the sum of the static and dynamic pressures is constant along a fluid steam. What are the static and dynamic pressures in the fluid just before reaching the small orifice? What are the static and dynamic pressures in the fluid issuing from the small orifice?
  • · Replies 19 ·
18K
