What Is the Speed of the Current in the River?
The discussion centers on calculating the speed of the current in a river based on a scenario involving a sunbather swimming against and then with the current. The key variables include the time spent swimming (15 minutes or 0.25 hours), the distance the raft drifts downstream (1.0 km), and the swimmer's velocity relative to both the ground and the water. The equations derived include Vgirl.ground = -(x/0.25) and Vraft = y/0.25, leading to the relationship Vgirl.water = Vgirl.ground - Vraft. The solution indicates that the speed of the current (v) is 2 km/h, with the swimmer's speed relative to the water (u) being variable.
  • Understanding of relative velocity concepts
  • Basic algebra for solving equations
  • Knowledge of distance, speed, and time relationships
  • Familiarity with physics principles related to motion in fluids
  • Study relative velocity in fluid dynamics
  • Learn to solve systems of equations involving multiple variables
  • Explore practical applications of motion equations in real-world scenarios
  • Investigate the effects of currents on swimming and boating
This discussion is beneficial for physics students, educators, and anyone interested in understanding motion in water, particularly in relation to swimming and currents.
Malgrif
A sunbather, drifting downstream on a raft, drives off the raft just as it passes under a bridge and swims against the current for 15min. She then turns and swims downstream, making the same total effort and overtaking the raft when it is 1.0km down stream from the bridge. What is the speed of the current in the river?
t= 0.25h
dr=1.0km
This question is owning me. Hard. I've tried at least 10different methods to crack this but, alas, I figure afterwards that my logic must be wrong, or stuff doesn't cancel out... I'll try to show my work at best I can but most of it is abstract so... Here goes.
Ok so we know that she travels x distance in 15mins opposite to the raft, so her velocity would be.
Vgirl.ground= -(x/0.25)
We also know that in the 15mins the raft travels y distance, and is effectively traveling with the current so,
Vraft= y/0.25
Now I know that the velocity that the girl is going at is her velocity relative the the ground, so we need to make her velocity relative to the water.
Vgirl.water= Vgirl.ground - Vraft
After around here my logic is hazy and I'm not quite sure how to continue next... Or if even what I'm doing up to this point is correct. Help would be appreciated =)
Sorry, I am old and can't wrap my mind around the particular variables you have used, but I see that you are on the right track. Humor me and think of
u = speed of swimmer with respect to the water
v = speed of water in river
t = time of swim downstream
t + .25 = time raft drifts downstream
d = distance swum upstream
Then write a d = vt equation for the raft, the upstream swim and the downstream swim.
You have unknowns u, v, t and d. And only 3 equations.
1 = v(t + .25) for the raft
d = (u-v)*.25 for swimming upstream
Curious - I find a solution of t = .25, v = 2 with ANY value you like for u.
  • · Replies 22 ·
