How do you calculate tension and frictional forces in a system of moving bodies?
  • Thread starter Thread starter undertow2005
    bodies System
The discussion revolves around calculating tension and frictional forces in a system involving two masses connected by a cord, subjected to an applied force on a horizontal surface. The original poster presents a scenario with specific values for mass and acceleration but lacks information on the coefficient of friction.
  • Participants discuss the application of Newton's second law to each mass, considering the forces acting on them. There are attempts to derive equations for tension and frictional force, along with questions about the direction of tension relative to the applied force.
Some participants have provided guidance on breaking down the problem into manageable parts and identifying forces. There is an ongoing exploration of the relationships between the forces and the roles they play in the equations, with no explicit consensus reached on the correct approach yet.
The original poster is working without a textbook and is under pressure to understand the problem before an upcoming exam. The lack of a coefficient of friction is noted as a constraint in solving the problem.
undertow2005
i'm working without my textbook and going by the some solutions that i have so i need some help
1) Two masses, m1 and m2, joined with a cord are dragged along the horizontal plane surface. the applied force is F=20N, mass m1=m2=3kg, and the acceleration is 0.50 m/s. what is the tension, T, in the connecting cord if the frictional forces on the two blocks blocks are equal? How large is the frictional force, F, on each block?
diagram:
| m1 |-----| m2|------>F
can you explain what you have done to try and solve this?
i've solved simpled problems--problems with only one body moving. so i tried to apply those principles here:
for tension:
T=3kg*.50
i know know that is wrong since there is a frictional force. i just don't know how to compute it since the coefficient of friction is not given
so, there it is. i didnt get very far into it.
Attack the problem step by step. Start, as always, by identifying all the forces acting on each of the masses. Draw a picture with those forces labeled. (All we care about are the horizontal forces.)
Once you've done that, there are several ways to proceed. Here's one way. Treat each mass separately and apply Newton's 2nd law. You'll get an equation for each mass. Combine them and you can solve for the tension in the cord and the fricitional force. Give it a shot.
i did give it a shot, please I'm totally lost here, my Final that i must Ace is tomorrow. please work this problem out for me, somebody
What forces are the front block subject to?
Clearly, the applied force F, a tensile force T, and a frictional force f.
Obviously, both the tensile force and the frictional force works in opposite direction than F, so we have for particle 2:
[tex]F-T-f=ma[/tex]
For the rear block, the tensile force has the same magnitude T, but works in the opposite direction.
Hence, we have:
[tex]T-f=ma[/tex]
You have only 2 unknowns here, T and f, and 2 equations..
from the equations i know how get get T and f. i have another question, how do you know T is opposite the force. i acutally thought T was going the same direction as the force for the box in the front. or is the tension always opposite the force. also, for the box in the rear, why did you leave out F out of the equation and not write F-T-f=m*a. i don't understand because the force is also acting on this box.
The tension in the cord exerts a pull (T) at both ends of the cord. According to your diagram, the cord pulls m1 to the right and m2 to the left.
The force F is only applied to mass m2; it does not touch m1. It will, of course, affect the tension in the connecting cord--but that's a separate force.
  • · Replies 18 ·
  • · Replies 17 ·
  • · Replies 45 ·
