Thread Closed
Dynamics Block
Share Thread Thread Tools
Feb22-09, 01:12 PM   #1
Dynamics Block
A 2.5 kg block is initially at rest on a horizontal surface. A horizontal force F of magnitude 6.0 N and a vertical force P are then applied to the block (the vertical force is upwards). The coefficients of friction for the block and surface are Ms = 0.40 and Mk = 0.25. Determine th emagnitude of the frictional force acting on the block if the magnitude of P is a) 8.0 N, b) 10 N, and c) 12 N
2. Relevant equations
fs = Mk * Fn
Fnet = ma
Fg - Fn - P = 0
3. The attempt at a solution
I tried using the third equation to get Fn and plug this value into the first equation to get force of friction. I didn't get the right answer... for P = 8.0 N the answer should be 6.0 N. How?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Feb22-09, 01:23 PM   #2
Mentor
Show exactly what you did. Hint: First you must determine whether the relevant friction is static or kinetic.
Feb22-09, 01:25 PM   #3
Quote by Doc Al View Post
Fg - Fn - P = 0
24.5 = Fn + 8
Fn = 16.5
fs = 16.5 * 0.25 = 4.1 N
Feb22-09, 01:31 PM   #4
Mentor
Dynamics Block
Quote by Shatzkinator View Post
Fg - Fn - P = 0
24.5 = Fn + 8
Fn = 16.5
Good.
This assumes that the block moves. Does it?
Feb22-09, 01:40 PM   #5
Good.
well Yea if the force applied is 6.0 N and the friction is 4.1 then yes it should move.
Feb22-09, 01:41 PM   #6
Oh wait no it doesn't because Fn * Ms = 8.25 which is greater than 6 N so it doesn't move. Now what?
Feb22-09, 01:52 PM   #7
Mentor
How does static friction work? Note that for static friction, μN is the maximum possible static friction that the surfaces can generate before being forced to move. But static friction will be only what it needs to be to prevent slipping (up to the maximum). How much does static friction need to be in this case to prevent slipping?
Feb22-09, 01:54 PM   #8
6 to prevent slipping?
Feb22-09, 01:58 PM   #9
Mentor
Right!
Thread Closed
Thread Tools
Similar Threads for: Dynamics Block
Thread Forum Replies
block being pushed along the floor (dynamics problem) Introductory Physics Homework 1
Dynamics of block with friction...how to set up? Introductory Physics Homework 1
Dynamics block problem Introductory Physics Homework 1
Rotational Dynamics - sphere,block,pulley Introductory Physics Homework 1
