Find the Equivalent Resistance of a Network
The discussion revolves around finding the equivalent resistance of a network that includes both parallel and series connections of resistors. Participants are analyzing the configuration of the resistors and applying the relevant formulas for series and parallel resistances.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants discuss the arrangement of resistors, with some initially interpreting certain resistors as being in series while others argue they are in parallel. There is an exploration of how to identify series and parallel connections based on shared nodes.
The discussion is active, with participants providing corrections and clarifications regarding the configuration of the resistors. Some have offered insights into the definitions of series and parallel connections, which has helped others in understanding the problem better.
There is a hint provided in the original post suggesting the use of series and parallel resistance formulas. Participants are also navigating through potential misunderstandings about the circuit layout, which may affect their calculations.
jumbogala
A network consists of a combination of parallel and series connections. What is the equivalent resistance of the network? (Hint: Use the series and parallel resistance formulas).
The network looks like this:
When a circuit is in series, R = R1 + R2 + R3...
When a circuit is in parallel, R = 1/R1 + 1/R2 + 1/R3...
First, c and b are in series, so I just add them up. 5 + 3 = 8.
Now, a, d, and this new resistor of value 8 are in series. So add them up again.
8 + 4 + 1 = 13.
Did I do that correctly?
Sorry. B and C are ||.
Not in series.
They look like they're in series to me... how can you tell?
That changes my answer to 1/5 + 1/3 = 0.533. And 1/0.533 = 1.875.
Then 1.875 + 4 + 1 = 6.875
That looks more like it.
This is wrong. I think you meant to write:
1/Req = 1/R1 + 1/R2 + 1/R3...
Notice that the upper terminals of C and B share a common node. Similarly, the bottom terminals of C and B share a common node.
Yeah, I meant to write 1/Req = 1/R1 + 1/R2...
So a is in series with c because it only shares one common node? And b and c are in parallel because they share two nodes?
Well, a better way to say it is this: A is in series with the combination C||B.
If the same current flows through two resistive elements, the elements are in series.
If the same voltage potential is across two elements, the elements are in parallel.
Does that help?
That helps a lot - I understand now. Thank you!
  • · Replies 23 ·
