Rates and Hess' Law: Questions and Answers
  • Thread starter Thread starter babbagee
    Law
This discussion addresses two key topics in chemical kinetics and thermodynamics: the calculation of concentrations in a first-order reaction and the application of Hess' Law. For the reaction A + 2B → C, with initial concentrations [A]₀ = 0.60 M and [B]₀ = 0.80 M, the concentration of A after 2 minutes is calculated using the first-order rate equation, [A] = [A]₀ exp(-kt), where k = 0.00625 s⁻¹. The concentration of B is derived by recognizing that for every mole of A consumed, two moles of B are also consumed, leading to [B] = [B]₀ - 2([A]₀ - [A]). The second part of the discussion clarifies the correct formulation of the reaction for the formation of Al₂O₃(s) from Al(s) and O₂(g) using Hess' Law.
  • Understanding of first-order reaction kinetics
  • Familiarity with the rate law and rate constant (k)
  • Knowledge of Hess' Law and heat of formation
  • Basic algebra for manipulating chemical equations
  • Study the derivation and application of the first-order rate equation in various chemical reactions
  • Learn about the concept of reaction stoichiometry and its impact on concentration changes
  • Explore Hess' Law in detail, including its applications in calculating enthalpy changes
  • Practice solving problems involving multiple-step reactions and their corresponding thermochemical equations
Chemistry students, educators, and professionals in chemical engineering or related fields who are looking to deepen their understanding of reaction kinetics and thermodynamic principles.
babbagee
I have two questions first on is on Rates and the second one is ont Hess' law.
1.) If [A]o = .60 M and o = .80 M, what are the concencentrations of A and B after 2 minutes?
Heres the reaction: A + 2B --> C
The Rate law for this reaction is R=k[A]
k = .00625s-1
I found the concentration of A which is a direct plugin to the rate law, but i don't know how to get the concentration of B. The concentration of B at two mintues should be two time less than that of A, since two B's are being used up for every 1 A. I don't know how to go from there. Thanks
Second Question:
This problem involves Hess' law. The problem i am having is writing the equation for one of the sub reactions. I am given the heat of formation for
Al2O3(s). so Al2O3(s) comes from Al(s) and O2 right.
2Al(s) + (3/2)O2(g) ---> Al2O3(s)
I think i am not doing this eqaution right that is why i am having a hard time with the overall problem.
Thanks
Chemistry news on Phys.org
1) This is first order reaction kinetics
d[A]/dt = -k[A] ,
=>d[A]/[A] = -kdt. Now integrate this to get
ln([A]/[Ao]) = -kt is the integral rate equation, which can also be written as
[A] = [Ao] exp(-kt)
Now it's just a matter of plugging in numbers to get [A]. Ooops, just realized that you've done this part already.
Like you said (but not exactly), for every mole of A that reacts, 2 moles of B disappear. So find [Ao] - [A] and multiply this by 2. This gives you the change in conc. of B. If you subtract this from [Bo], you have your answer.
2) There's nothing wrong with what you've written so far. Why do you think it's wrong ? What are you trying to calculate in this problem ? Perhaps explaining the complete problem might help.
Thanks for part 1, I realized that i don't need help for part 2 i just figured it out. It was a hess' law problem and i kept trying to do it in my head and each time i tried it, it seemed like i had some oxygen's left over. I worte it on paper and it all worked out, so i don't need help on part two anymore. But thanks for the help on part 1.
  • · Replies 131 ·
11K
