Can the Poisson-Boltzmann Equation Be Solved Using Power Series?
  • Context: Graduate
  • Thread starter Thread starter nassboy
The discussion revolves around the Poisson-Boltzmann equation and the exploration of solutions using power series and analytical methods. Participants are investigating both closed form and approximate solutions, with a focus on the challenges posed by the equation's complexity.
  • One participant presents a variant of the Poisson-Boltzmann equation and discusses their attempts to generate a power series using recursive derivatives.
  • Another participant suggests an analytical approach involving substitutions and transformations to simplify the equation, leading to an integral that may require numerical methods for evaluation.
  • Concerns are raised about the steep curvature of the integral, which complicates numerical integration methods.
  • A later reply proposes a closed form solution derived from series expansions, although it is noted that the solution is complex and may not be straightforward to work with.
  • Participants discuss the possibility of inverting the series to express y as a function of x, raising questions about the convergence of the series.
  • One participant mentions difficulties encountered while implementing the series solution in Mathematica, suggesting potential issues with convergence or errors in their approach.
  • Another participant introduces the Lagrange inversion theorem as a method to derive a series expansion for y in terms of x, emphasizing the need for careful analysis of the function's behavior.
Participants express differing views on the best approach to solving the equation, with some favoring power series methods and others leaning towards analytical solutions. The discussion remains unresolved regarding the most effective method to obtain a solution.
There are limitations regarding the convergence of series and the assumptions made during transformations and substitutions. The validity of switching between summation and integration has not been verified, and the complexity of the integrals involved poses additional challenges.
nassboy
I've been working on finding a closed form solution or an approximate solution for a variant of the Poisson-Boltzmann equation.
y''[x]=A*(1-e^(-y[x])
I'm unable to solve it using methods such as separation of variables, but I have been able to generate a power series using recursive derivatives. I've pasted the mathematica code below...I've been unable to find the pattern to generate the series...can anybody help?
In[2]:= (*Define Recursive Derivative Function *)
In[3]:= Derivative[N_][Y][0]:=D[Y''[x],{x,N-2}] /. x->0
In[4]:= (*Define the Problem*)
In[5]:= Y''[x]=A*(1-E^(-Y[x]))
Out[5]= A (1-E^-Y[x])
In[6]:= Y''[0]=Y''[x] /. x->0
Out[6]= A (1-E^-Y[0])
In[7]:= Y'[0]=0
Out[7]= 0
In[8]:= (*Check the Series*)
In[9]:= Y[0]+Integrate[Integrate[Series[Y''[x],{x,0,10}],x],x]
Out[9]= Y[0]+1/2 (A-A E^-Y[0]) x^2+1/24 A^2 E^(-2 Y[0]) (-1+E^Y[0]) x^4-1/720 (A^3 E^(-3 Y[0]) (4-7 E^Y[0]+3 E^(2 Y[0]))) x^6+(A^4 E^(-4 Y[0]) (-34+82 E^Y[0]-63 E^(2 Y[0])+15 E^(3 Y[0])) x^8)/40320-((A^5 E^(-5 Y[0]) (496-1510 E^Y[0]+1638 E^(2 Y[0])-729 E^(3 Y[0])+105 E^(4 Y[0]))) x^10)/3628800+(A^6 E^(-6 Y[0]) (-11056+40540 E^Y[0]-56568 E^(2 Y[0])+36684 E^(3 Y[0])-10545 E^(4 Y[0])+945 E^(5 Y[0])) x^12)/479001600+O[x]^13
Hello nassboy,
I am not able to help you in finding a solution using mathematica but I can help you in finding a solution analytically. That is to say, the final integral you need to solve numerically or by another method. OK, so first substitute the following variables:
[tex]u=y \qquad v=y' \qquad w=\frac{dv}{du}=\frac{y''}{y'}[/tex]
or:
[tex]y=u \qquad y'=v \qquad y''=v\frac{dv}{du}[/tex]
This comes from the fact that the original equation does not have x explicitely used. This gives now:
[tex]v\frac{dv}{du}=A*\left(1-e^{-u}\right)[/tex]
And solved for v:
[tex]v=\sqrt{K_1+2A*\left(u+e^{-u}\right)}[/tex]
Or using the opposite of the substitution:
[tex]\frac{dy}{dx}=\sqrt{K_1+2A*\left(y+e^{-y}\right)}[/tex]
From which:
[tex]x+K_2=\int \frac{dy}{\sqrt{K_1+2A*\left(y+e^{-y}\right)}}[/tex]
In which [itex]K_1[/itex] and [itex]K_2[/itex] are the integration constants. This final integral is probably not solvable in an ordinary way, so other methods are necessary, perhaps it is the starting point for the series you are looking for.
Hope this helps,
coomast
Thanks for looking at my problem...
The reason I went to a series approach in the first place was that I didn't know how to tackle that ugly integral. It has very steep curvature so quadrature methods don't work well...
Mmm, if really necessary I can look up the quadrature methods for finding integrals in order to come up with a formula for finding it numerically with the greatest degree of algebraic accuracy -if I recall well- it was called. This can take a day or two because this has been some time. Maybe I can find a different -and for this case- a better way of solving it. Do you want me to look for something?
coomast
Nah,
I'm more interested in a closed form approximate solution...
some function Y[x]=, that is close to the real solution
nassboy said:
Nah,
I will have a look at it tomorrow. I'm not promising anything but I will give it a try.
coomast
thanks!
hello nassboy,
I had a look at the integral again and came up with a closed form solution. However this is not an easy solution and difficult to work with, although, if you are going to use it in a program it might be the solution you are looking for. But first some relations I used in deriving this solution.
[tex] \frac{1}{\sqrt{1+x}}=1-\frac{1}{2}x+\frac{1 \cdot 3}{2 \cdot 4}x^2-<br /> \frac{1 \cdot 3 \cdot 5}{2 \cdot 4 \cdot 6}x^3+...=<br /> \sum_{i=0}^{\infty}\frac{(2i)!\cdot (-1)^i}{\left(2^i\cdot i!\right)^2}x^i[/tex]
[tex] (A+B)^i=\sum_{k=0}^{i}\frac{i!}{k!\cdot (i-k)!}A^k\cdot B^{i-k}[/tex]
[tex] e^{-by}=\sum_{p=0}^{\infty}\frac{(-by)^p}{p!}[/tex]
So the first step is to rewrite the integral as:
[tex] x+K_2=\frac{1}{\sqrt{K_1}}\int<br /> \frac{dy}<br /> {\sqrt{1+\frac{2A}{K_1}(y+e^{-y})}<br /> }[/tex]
Expanding the denominator using the first relation gives:
[tex] x+K_2=\frac{1}{\sqrt{K_1}} \sum_{i=0}^{\infty} \frac{(2i)!\cdot (-1)^i}{\left(2^i\cdot i!\right)^2}<br /> \cdot \left(\frac{2A}{K_1}\right)^i \cdot<br /> \int (y+e^{-y})^i dy[/tex]
This under the assumption that the switching of the summation and the integral is allowed, meaning that it must converge. I didn't check this. Using the second relation we can rewrite this new integral as:
[tex] \int (y+e^{-y})^i dy=\sum_{k=0}^{i} \frac{i!}{k!\cdot (i-k)!}<br /> \int {y^ke^{-(i-k)y}}dy[/tex]
The final integral now can be found by the third relation:
[tex] \int {y^ke^{-(i-k)y}}dy=\sum_{p=0}^{\infty}<br /> \frac{(-1)^p (i-k)^p}{p!} \int y^{k+p}dy=<br /> \sum_{p=0}^{\infty} \frac{(-1)^p (i-k)^p}{p!}\cdot \frac{y^{k+p+1}}{k+p+1}[/tex]
The complete solution now becomes:
[tex] x+K_2=\frac{1}{\sqrt{K_1}}<br /> \sum_{i=0}^{\infty} \left[<br /> \frac{(2i)!\cdot (-1)^i}{\left(2^i\cdot i!\right)^2}<br /> \cdot \left(\frac{2A}{K_1}\right)^i \cdot \right. \\<br /> \left.<br /> \left(\sum_{k=0}^{i} <br /> \left[\frac{i!}{k!\cdot (i-k)!} \cdot \left(<br /> \sum_{p=0}^{\infty} \frac{(-1)^p (i-k)^p}{p!}\cdot \frac{y^{k+p+1}}{k+p+1}<br /> \right)\right]\right)\right][/tex]
I can't garantee that this is without error. As stated before the convergence checks needed for getting approval for the switching between the integral and the sums are not done.
Hope this helps a bit,
coomast
Wow I'm impressed! I wouldn't have come up with that in ages! I'll try to verify it tomorrow or Monday!
I have one more, perhaps, naive question. Is one able to invert a series like that to get a function for y, for example y(x)=Series?
I tried to implement the series solution in Mathematica and did not get the results that I expected. Perhaps the series does not converge...perhaps I made a mistake.
Maybe you can use the http://en.wikipedia.org/wiki/Lagrange_inversion_theorem" to get a series expansion?
If you set your initial conditions to be [itex]y(x_0) = y_0[/itex] and [itex]y'(x_0) = y'_0 \neq 0[/itex], then you can solve for x in terms of the integral over y as coomast did (I kept the plus/minus sign from taking the square root):
[tex]x = x_0 \pm \int_{y_0}^{y}\frac{du}{\sqrt{2A(u + e^{-u}) + C_0}} \equiv f(y)[/tex]
where [itex]C_0 = -2A(y_0 + e^{-y_0}) + (1/2)(y'_0)^2[/itex]. Then we want y = g(x), which we can find with the inversion theorem. Now, hopefully the solution is analytic at the initial value (or anywhere - if it's not then the whole thing breaks down), so referring to the wikipedia article, let's choose [itex]a = y(x_0) = y_0[/itex] and [itex]b = x_0[/itex]. So, then by the theorem,
[tex]g(x) = y_0 + \sum_{n=1}^{\infty}\frac{d^{n-1}}{dy^{n-1}}\left.\left(\frac{y-y_o}{f(y)-x_0}\right)^n\right|_{y=y_0}\frac{(x-x_0)^n}{n!}[/tex].
In the first order (n=1) term in the sum we have to use L'Hopital's rule as y -> y_0. Doing so, I get,
[tex]y = g(x) = y_0 \pm\sqrt{2A(y_0+e^{-y_0})+C_0}(x-x_0) + \sum_{n=2}^{\infty}\frac{d^{n-1}}{dy^{n-1}}\left.\left(\frac{y-y_o}{f(y)-x_0}\right)^n\right|_{y=y_0}\frac{(x-x_0)^n}{n!}[/tex].
The higher order terms look like they'll be ugly to evaluate, but in principle you can churn out each term in the expansion to get your series expansion. You would likely want to check your result against numerical solutions to the equation to make sure it's capturing the correct behaviour at small values of y, as using the theorem does assume that f(y) is analytic when I haven't actually checked that.
