How does an electron behave in a closed time like curve?
The discussion centers around the behavior of electrons and other fermions in the context of closed timelike curves (CTCs) within the framework of quantum field theory (QFT). Participants explore theoretical implications, potential interference with past states, and the role of bosons versus fermions in these scenarios.
  • Some participants propose that an electron can loop through time without issue in the first two loops, but question the implications of a third loop, such as whether it would interfere with its own past or be destroyed.
  • Others argue that bosons could mitigate problems associated with CTCs by interfering constructively, potentially preventing issues before they arise.
  • A participant mentions that QFT loses its particle nature in tightly curved spacetimes, suggesting that particles behave differently in such conditions.
  • Another participant challenges this view, stating that QFT loses its particle nature when the time coordinate is not well defined, and provides an example of a cylindrical universe where the time coordinate is well defined despite the presence of CTCs.
  • There is a discussion about the wave function of particles in CTCs, with one participant asserting that the wave function remains a one-particle function and that the statistics of particle exchange become irrelevant.
  • Some participants express a desire for sources or reasoning to support claims made about the behavior of particles in CTCs.
Participants express differing views on the implications of CTCs for fermions and bosons, with no consensus reached on how these particles behave in such scenarios. The discussion remains unresolved regarding the nature of particles in curved spacetimes and the effects of CTCs.
Limitations include the dependence on specific definitions of time and spacetime curvature, as well as unresolved mathematical steps regarding the behavior of particles in CTCs.
MTd2
So, it goes in the first loop, no problem. In the second loop, no problem either, it could just change the spin. So, what about the third, will the electron interfere with its own past? Will it be destroyed? Will it mysteriously scatter and not interfere with its past.
This is the same for all ferminos, but bosons won't have this issue.
Yes but bosons do help you very much in this problem. By interfering constructively, if I recall correctly, they will blow up your loop before it becomes a real problem :smile:
Really? Any source or reasoning?
BTW, I was thinking more about fermions because of the exclusion principle.
Actually, QFT loses its particle nature in tightly curved spacetimes. Particles are described by plane waves in flat spacetime that propagate both forward and backward in time. But in curved spacetimes planewaves no longer act like planewaves.
I originally read about it in Kip Thorne's "Black and time warps". I can dig up the references if you want.
The wave function is still of the form [tex]\psi({\bf x},t)[/tex], not [tex]\psi({\bf x}_1, {\bf x}_2, {\bf x}_3, ...,t)[/tex]. In other words, it is still a 1-particle wave function. Consequently, the statistics is irrelevant, the concept of particle exchange does not make sense, there is no difference between bosons and fermions. The electron will have the same spin in each loop, simply because it is the same self-consistent electron.
The only interesting stuff is the following. Due to CTC, the wave function must be periodic in time. Consequently, energy is quantized even though the particle is not in a potential well.
Wrong! QFT loses its particle nature when the time coordinate is not well defined. On the other hand, in our case the time coordinate may be well defined. Take for example a cylindrical universe, in which the compact coordinate is the time coordinate. In this case the metric is flat, but there is a CTC.
  • · Replies 0 ·
  • · Replies 62 ·
13K
  • · Replies 26 ·
  • · Replies 27 ·
  • · Replies 21 ·
