Bubble sort 2D int array with c
The discussion centers on implementing a bubble sort algorithm for a 2D integer array in C, specifically sorting an array defined with 15 rows and 2 columns. The user encounters compilation errors due to incorrect function argument types when calling the bubblesort function. The solution involves passing the entire 2D array to the function instead of a single row, correcting the function call to bubblesort(deck). Additionally, the code contains logical errors in the sorting loops that need to be addressed for proper functionality.
  • Understanding of C programming language syntax
  • Familiarity with 2D arrays in C
  • Knowledge of sorting algorithms, specifically bubble sort
  • Experience with function prototypes and parameter passing in C
  • Review C programming documentation on 2D arrays and pointers
  • Study the implementation of bubble sort in C with examples
  • Learn about debugging compilation errors in C, focusing on type mismatches
  • Explore alternative sorting algorithms for 2D arrays, such as quicksort or mergesort
C programmers, computer science students, and anyone looking to improve their understanding of sorting algorithms and 2D array manipulation in C.
clope023
hi, I'm not sure if there is a homework forum for programming but I thought I'd post my problem here; I'm supposed to bubble sort a 2d integer array with elements 15 and 2; this is what my code looks like so far:
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
#define cards 15
#define sides 2
void bubblesort(int items[cards][sides]);
int main()
int i, stime;
long ltime; ltime = time(NULL);
stime = (unsigned)ltime/2;
srand(stime);
int deck[cards][sides];
for(i=1;i<=15;i++)
{ deck[0]=i;
deck[1]=rand();
printf("%d ", deck[0]);
printf("%d\n", deck[1]);
bubblesort(deck[0]);
return 0;
}void bubblesort(int items[cards][sides])
int a,b,c,d,t;
for(a=1;a<=cards;a++)
for(b=0;b<sides;b++)
for(c=cards-1; c>=cards;c--)
for(d=sides-1; c>=sides;d--)
if(items[c-1][d-1] > items[c][d])
t=items[c-1][d-1];
items[c-1][d-1] = items[c][d];
items[c][d] = t;
it keeps on returning the same 2 errors
initializing argument 1 of void bubblesort(int (*)[2])
and invalid conversion from int to int(*)[2]
I'm not sure what kind of 'conversion' is going on; I've tried changing the variable array for bubblesort to pointer and to memory address but that gave extra errors; any help on what I might be doing wrong is appreciated
On this line of your code
Code:
bubblesort(deck[i][0]);
You are sending an int to your bubblesort function, when your prototype says you are expecting a pointer to a pointer (int **). Try changing it to
Code:
bubblesort(deck)
But from looking at the way you have used memory, you are bound to have more problems.
  • · Replies 17 ·
11K
  • · Replies 17 ·
