Thread Closed
Series versus Parallel Capacitors
Share Thread Thread Tools
Feb26-09, 01:02 PM   #1
This is not so much a homework as just a general question.
I understand the reasoning behind capacitors in a series all of have same charge, which consequently causes each one to have a separate voltage. But why do capacitors in parallel not have the same amount of charge. They all receive the same voltage. Even though capacitance can differ among capacitors in a series, they still all have the same charge. Why would capacitance affect the charge of capacitors in parallel differently?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Feb26-09, 01:38 PM   #2
Recognitions:
Gold Membership Gold Member
Remember that voltage is a measure of how 'hard' the current pushes, not the amount. The current in a parallel series is split, so why wouldn't the amount of charge be split too? Basically current is the net flow of electrons in some time. so when the amount of electrons in some time vary for the entire circuit why wouldn't the amount of electrons stored in any one capacitor be different.
Someone correct me if I'm off on some definition here but I believe the idea is correct. My electricity is a tad rusty but this answer seemed the most obvious to me.
Feb27-09, 10:44 AM   #3
is it possible for two capacitors the following two capacitors to exist: one has a capacitance of 4F and a charge of +q, and the other has a capacitance of 2F and a charge of +5q.
I think that is it because capacitance is simply a constant that describes the rate of change of charge per unit voltage. If the +5q capacitor has a voltage of 5v, then the two capacitors would be feasible.
Since factors such as dielectrics, area and distance determine the capacitance, then it it possible for the two capacitors to exist.
Can anyone give me a hand on this one?
Feb27-09, 10:56 AM   #4
Recognitions:
Homework Helper Homework Help
A capacitor is something that holds charge. If you add a couple in parallel then it's like you have more than one cup lined up to pour charge into.
Q = V*C
or just looking at the capacitor it's C = Q/V.
As you noted if they are in series the charges equalize across the equivalent capacitor, and the lower voltage at each yields lower charges at each. (The equivalent capacitance is less, the reverse of when they are in parallel.)
Thread Closed
Thread Tools
Similar Threads for: Series versus Parallel Capacitors
Thread Forum Replies
Help distinguishing between series and parallel capacitors Introductory Physics Homework 6
Capacitors in Parallel and Series Introductory Physics Homework 4
Capacitors in series and parallel Introductory Physics Homework 6
charge on capacitors in parallel and series Introductory Physics Homework 1
