Capacitors connected to each other
  • Thread starter Thread starter magevivi
    Capacitors
When two capacitors, one with a capacitance of 4.30 µF and the other with 12.1 µF, are connected in parallel across a 9.0-V battery, they charge to 38.7 µC and 108.9 µC, respectively. Upon reconnection with opposite plates joined, the charges redistribute, leading to a new potential difference across each capacitor. The net charge across the two capacitors cancels, and the voltage can be determined using the equivalent capacitance and the total charge.
  • Understanding of capacitor charging and discharging principles
  • Familiarity with the formula C = Q/V
  • Knowledge of parallel capacitor configurations
  • Basic concepts of electric charge and voltage
  • Calculate the equivalent capacitance of capacitors in parallel
  • Learn about charge redistribution in capacitors
  • Explore the effects of connecting capacitors with opposite polarities
  • Study the relationship between charge, voltage, and capacitance in electrical circuits
Students studying electrical engineering, physics enthusiasts, and anyone looking to deepen their understanding of capacitor behavior in circuits.
magevivi
Two capacitors, one that has a capacitance of 4.30 µF and one that has a capacitance of 12.1 µF, are connected in parallel. The parallel combination is then connected across the terminals of a 9.0-V battery. Next, they are carefully disconneted so that tehy are not discharged. They are then reconnected to each other--the positive plate of each capacitor connected to the negative plate of the other. Find the potential difference across each capacitor after they are reconnected.
C1 = 4.30µF
C2= 12.1µF
V = 9v
C = Q/V
Before they are reconnected each capacitor is charged to the following:
C1(V) = Q1 --> (4.3µF)(9v) = 38.7µC
C2(v) = Q2 --> (12.1µF)(9v) =108.9µC
But I lose my way after the reconnection. I understand that the voltage will change are charge will rearrange but when it comes to the specifics I am not entirely sure. Any help would be appreciated.
Welcome to PF.
What happens to the positive charge of the one capacitor and the negative charge of the other when they are connected?
Did I hear you say they cancel? Good.
So if they cancel what is the net charge across the 2 capacitors?
And since you are already armed with the equivalent capacitance ... and you know the charge ... hmm I wonder how to find the voltage?
