Total Transmission Across Finite Barrier Potential with E>V
The discussion focuses on calculating the thickness of a potential barrier required for total transmission of electrons with a kinetic energy of 350 eV, given a barrier height of 200 eV. The transmission equation used is T=|t|^2=1/(1+(V0^2sin^2(k1a)/(4E(E-V0)))), where k1 is defined as √(2m(V0-E)/ħ²). The user correctly identifies that setting T=1 leads to the condition for zero reflection, resulting in the equation a=nπ/√(2m(V0-E)/ħ²) for the barrier thickness.
  • Quantum mechanics fundamentals, particularly wave-particle duality
  • Understanding of potential barriers and tunneling phenomena
  • Familiarity with the Schrödinger equation and wave functions
  • Basic knowledge of electron properties, including mass and kinetic energy
  • Study the derivation and implications of the transmission coefficient in quantum mechanics
  • Learn about the concept of wave functions and their role in quantum tunneling
  • Explore the effects of varying barrier height and width on electron transmission
  • Investigate the relationship between wave number and barrier length in quantum systems
Students and professionals in physics, particularly those specializing in quantum mechanics, as well as researchers working on electron transport phenomena in nanostructures.
Dahaka14
A beam of electrons of KE = 100 eV is incident from the left on a barrier
which is 200 eV high and 10 nm wide. If the momentum spread is sufficiently
narrow, then a simple plane wave is a good approximation. Recall that the mass of an
electron is mc2 = 511 keV.
....._____
...1...|..2...|...3
__________|...|____________
.....x=0...x=10 nm
(periods are there to preserve picture upon post)
If the energy of the electrons is raised to 350 eV, what thickness should the barrier be
to give transmission with no reflections?
[tex]T=|t|^2= \frac{1}{1+\frac{V_0^2\sin^2(k_1 a)}{4E(E-V_0)}}[/tex]
where [tex]k_1=\sqrt{2m (V_0-E)/\hbar^{2}}[/tex]
I am almost positive I just use the above equation, set [tex]T=1[/tex], then solve for [tex]a[/tex] because we know every other variable. I ended up with the general equation (no substitution for values yet)
[tex]1=\frac{1}{1+\frac{V_0^2\sin^2(k_1 a)}{4E(E-V_0)}}\iff 1=1+\frac{V_0^2\sin^2(k_1 a)}{4E(E-V_0)}\iff 0=\frac{V_0^2\sin^2(k_1 a)}{4E(E-V_0)}\iff 0=\sin^2(k_1 a)\iff n\pi=\sqrt{2m (V_0-E)/\hbar^{2}}a[/tex]
[tex]\iff a=\frac{n\pi}{\sqrt{2m (V_0-E)/\hbar^{2}}}[/tex].
This solution makes me uneasy for some reason. Can someone point me out if I am wrong?
sounds reasonable, though i haven't checked your transmission equation - the transmssion condition will be when the probability waves add up constructively on transission & 100% destructively on releflection
so check this means 0 reflection..
also think about what this means for the wave number k1 (1/wavelength effectively) vs the length of the barrier...
