Ampere/Maxwell law capacitor problem
  • Thread starter Thread starter mcshadypl
    Capacitor Law
The discussion centers on calculating the electric and magnetic fields in a capacitor setup using the Ampere-Maxwell law. A 0.200-A current charges a capacitor with circular plates of 10.0 cm radius and 4.00 mm separation. The time rate of increase of the electric field between the plates can be derived from the Ampere-Maxwell law, specifically using the equation integral(B*ds) = μ0I + ε0μ0*(d(fluxE)/dt). The magnetic field at a point 5.00 cm from the center of the plates requires further analysis of the electric field's time variation.
  • Ampere-Maxwell law
  • Understanding of electric fields and magnetic fields
  • Basic calculus for time derivatives
  • Knowledge of capacitor characteristics and configurations
  • Calculate the time rate of increase of the electric field using ε0 and the given current.
  • Explore the derivation of magnetic fields in capacitors using the Ampere-Maxwell law.
  • Investigate the relationship between electric field strength and magnetic field strength in time-varying fields.
  • Learn about the applications of the Ampere-Maxwell law in electromagnetic theory.
Students studying electromagnetism, physics educators, and anyone seeking to understand the relationship between electric and magnetic fields in capacitors.
mcshadypl
A 0.200-A current is charging a capacitor that has circular plates 10.0 cm in radius. If the plate separation is 4.00 mm, (a) what is the time rate of increase of electric field between the plates? (b) What is the magnetic field between the plates 5.00 cm from the center?
Ampere-Maxwell law:
integral(B*ds) = u0I + e0u0*d(fluxE)/dt
I have found the solution to part A, but B is what is causing me trouble. I have really no clue how to go about finding the magnetic field.
What does the Ampere-Maxwell law tell you? What do each of the terms represent?
Well, it tells us what the magnetic field is that is created by a time-varying electric field as well as a conduction current. Since a capacitor is being considered, the latter part can be disregarded.
So I'm thinking that a cylinder can be constructed between the capacitors and we will assume that EA= u0e0*d(fluxE)/dt
I suppose that area, A, can represent the surface area of this cylinder such that A= pi(0.05m)2*(0.004m). So we want to find the magnetic field, which should be the "B" term of the integral portion of the equation. At this point I don't know how to proceed with the problem.
  • · Replies 18 ·
  • · Replies 26 ·
17K
