Three spheres attached by conducting wire
The discussion focuses on calculating the total charge Q of a system of three conducting spheres connected by thin wires, given the electric field E_a at the surface of sphere A. Using Gauss's Law, the charge on sphere A is determined as q_a = 4πa²ε₀E_a. The relationship between the charge of one sphere and the total charge is expressed as Q = (aE_a/k_e)(a+b+c). Additionally, the work required to bring a small charge q from infinity to sphere B is calculated as W = k_e(qQ)/(b), where Q is derived from the previously established equations.
  • Understanding of Gauss's Law and its application in electrostatics
  • Familiarity with electric fields and potential energy concepts
  • Knowledge of conducting spheres and charge distribution
  • Basic proficiency in algebra and manipulation of equations
  • Study the implications of charge distribution in connected conductors
  • Learn about electric potential and its calculation for multiple charges
  • Explore advanced applications of Gauss's Law in complex geometries
  • Investigate the concept of electric field strength in relation to charge and distance
Physics students, electrical engineers, and anyone interested in electrostatics and the behavior of conducting materials in electric fields.
valarking
Three conducting spheres of radii a, b and c, respectively, are connected by negligibly
thin conducting wires as shown in figure 4. Distances between spheres are much larger
than their sizes. The electric field on the surface of the sphere of radius a is measured to
be equal to [tex]E_a[/tex]. What is the total charge Q that this system of three spheres holds? How
much work do we have to do to bring a very small charge q from infinity to the sphere of
radius b?
http://www.vkgfx.com/physics/fig4.jpg
The attempt at a solution
This one I wasn't so sure about. In order to find the total charge, I first applied Gauss's Law to find the charge of one sphere, A, given the electric field on its surface. So [tex]\oint {\vec{E} \cdot d\vec{A}} = \frac{Q_{enclosed}}{\epsilon_0}[/tex] is used to get:
[tex]4\pi{a^2}E_a = \frac{q_a}{\epsilon_0}[/tex], or [tex]q_a = 4\pi{a^2}\epsilon_0{E_a}[/tex].
To get the relationship between one sphere and the total charge in a system of conducting connected spheres, I used this equation, which I'm not so sure about.
[tex]q_A = \frac{Qa}{a+b+c}[/tex]
I'm not sure if the radii should be squared.
Solving for Q gives:
[tex]Q = \frac{{a}E_a}{k_e}(a+b+c)[/tex]
Now for the second part, again I wasn't sure of this. But you could say the work going from infinitely far to right at sphere B would be the difference in potential energies.
So:
[tex]k_e\frac{q{q_b}}{b} - k_e\frac{q{q_b}}{\infty}[/tex]
where the infinity cancels out the second fraction and leaves:
[tex]k_e\frac{q{q_b}}{b}[/tex]
as the answer.
Plugging in b's charge gives:
[tex]\frac{k_e{q}{Q}}{a+b+c}[/tex]
I believe that any effect a or c would have on charge q's potential would be small enough not to matter. I am correct in this assumption?
The spheres are connected by conductors - so they have the same potential.
Figure out the potential on sphere a, then use that to find the charges on the others.
  • · Replies 23 ·
