Thread Closed
Net Force of Point Charges, Coulomb's law
Share Thread
Mar2-09, 09:27 AM   #1
The drawing shows three point charges fixed in place. The charge at the coordinate origin has a value of q1 = +8.02 C; the other two have identical magnitudes, but opposite signs: q2 = -4.73 C and q3 = +4.73 C. (a) Determine the net force exerted on q1 by the other two charges. (b) If q1 had a mass of 1.50 g and it were free to move, what would be its acceleration?
2. Relevant equations
F= kq1q2/r^2
F=ma
3. The attempt at a solution
F = k(8.02E-6C)(4.73E-6C)/(1.3^2)
F= 0.20179N
The horizontal componenets of the Force vectors cancel out and the vertical components are both pointing straight up. I think I want to find the net vertical force so I did:
sin23 = x/0.2017
x = -0.1707N <--I thought this was the Force on q1 from one of the charges so in order to get the net force I doubled it = -0.3415N
This answer didn't look right and it wasn't but i'm really confused how to get the net force.
For part b I'm pretty sure I understand how to figure it out I just need the answer from part a to solve it.
F = ma --> a=F/m
m=1.5g -->0.0015kg
a= (?F?)/0.0015kg
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Mar2-09, 10:00 AM   #2
"sin23 = x/0.2017
x = -0.1707N"
If you are using a calculatro, check the settings, I get something different from this one. Also pay attention to the sign, now it's contradicting with the picture.
Mar2-09, 10:40 AM   #3
Mentor
Quote by kgigs6 View Post
Rethink the direction of the vertical components.
sin23 = x/0.2017
x = -0.1707N
The angle is 23 degrees, not radians. (You have your calculator set to radian mode.)
Mar2-09, 11:06 AM   #4
Thanks! I got it right, and because I changed my calculator back to degrees I also was able to figure out why another problem wasn't working - Thanks for your help!
Thread Closed
Similar discussions for: Net Force of Point Charges, Coulomb's law
Thread Forum Replies
position three point charges so net force is zero Introductory Physics Homework 8
Coulomb's law, balancing a ball with point charges Introductory Physics Homework 3
Point Charges in a Square: Could the Force on Each Be Zero? Advanced Physics Homework 10
[SOLVED] Two point charges, Zero Net Force Introductory Physics Homework 14
Force of 2 Point Charges Introductory Physics Homework 3
