Force of wire in a magnetic field
The discussion focuses on calculating the force exerted on a wire carrying a current of 2.97 A positioned at an angle of 37.4° in a magnetic field of 0.889 T. The formula used is F = ILBsin(theta), where F is the force, I is the current, L is the length of the wire, and B is the magnetic field strength. The user initially calculated the force as -1.867 N but later realized the error stemmed from using the sine function in radian mode instead of degree mode. The correct calculation should yield a positive force value.
  • Understanding of the formula F = ILBsin(theta)
  • Knowledge of current (I), magnetic field strength (B), and wire length (L)
  • Familiarity with trigonometric functions, specifically sine
  • Ability to switch between degree and radian modes on a calculator
  • Review the application of the formula F = ILBsin(theta) in different scenarios
  • Learn about the effects of angle on force calculations in magnetic fields
  • Explore the significance of unit conversions in physics problems
  • Study common mistakes in trigonometric calculations and how to avoid them
Physics students, educators, and anyone involved in electromagnetism or electrical engineering who seeks to understand the interaction between current-carrying wires and magnetic fields.
Cheezay
A wire with a current of 2.97 A is at an angle of 37.4° relative to a magnetic field of 0.889 T. Calculate the force exerted on a 2.40 m length of the wire.
F= ILBsin(theta)
I'm under the impression that the problem gives me all the information i need, so:
F - The force I need to find
I - The given current 2.97A
L - Length of wire - 2.4m
B - .889T
sin(37.4) = -.2948 (Could my mistake be here?)
I multiply all of these values together (2.97A)(2.4m)(.889T)(-.2948) and i get = -1.867N, which isn't correct... any suggestions?
Your calculator is in radian mode. That's all.
Thanks very much, problem solved!
  • · Replies 23 ·
