Dielectrics influence on series/parallel
  • Thread starter Thread starter Dopefish1337
    Dielectrics
The discussion revolves around the effects of inserting a dielectric slab between the plates of two identical capacitors in series and parallel configurations. Participants are tasked with determining how various parameters such as potential difference, charge, capacitance, and potential energy are affected by the introduction of the dielectric.
  • Mixed
  • Participants explore the implications of inserting a dielectric on the potential difference and charge of capacitors in series and parallel.
  • Some participants question the assumption that charge remains constant in series configurations, suggesting that charge can change due to interactions between the capacitors.
  • Others discuss the relationship between capacitance and charge, particularly how dielectrics influence these values.
  • There are attempts to apply specific values to the equations governing capacitors to clarify the effects of the dielectric.
The discussion is ongoing, with participants offering various interpretations of how the dielectric affects the system. Some have provided calculations to support their reasoning, while others are still grappling with the implications of their findings. There is no explicit consensus yet, as different perspectives on the charge and potential differences are being explored.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the assumptions they can make. The discussion includes considerations of how the capacitors are connected to a battery, affecting their potential differences.
Dopefish1337
Fig. 1 and 2 show a dielectric slab being inserted between the plates of one of two identical capacitors, capacitor 2. Select the correct answer to each of the statements below (enter I for `increases', D for `decreases', or S for `stays the same').
http://img99.imageshack.us/img99/763/prob45.gif
A. In Fig. 1, the potential difference between the plates of capacitor 2 _______ when the dielectric is inserted.
B. In Fig. 1, the charge on capacitor 2 _______ when the dielectric is inserted.
C. In Fig. 2, the capacitance of capacitor 1 _______ when the dielectric is inserted.
D. In Fig. 2, the potential energy stored in capacitor 1 _______ when the dielectric is inserted.
For Capacitors in parallel: Ceq=C1+C2+C3...
In series 1/Ceq=1/C1+1/C2+1/C3...
The introduction of a dielectric increases capcitence to C=kC0
Energy stored on a Capacitor is uc=(1/2)C(deltaVc)2
C=Q/(deltaV)
For A, since the capcitors are in series, the charge on each must be constant, as no charge flow could reach the region between the two capacitors. Thus when the dielectric is added to #2, the potential difference across it must go down from deltaV=Q/C. Therefore, D, for decreases.
For B, due to the above reasoning, the charges can't have changed, so the answer would be S, stays the same.
For C, they are in parallel, so the potential difference across each is a constant. When the dielectric is added to #2, it's capacitence would go up, increasing the charge on that one, however, this shouldn't influence the capacitence on #1, so again, S, for stays the same.
For D, the energy is uc=(1/2)C(deltaVc)2, so since the potential difference hasn't changed, and C hasn't changed, this would also be S, stays the same.
I feel reasonably confident that C and D should have the same answer, so I suspect if one of those two is wrong, the other is wrong in the same way. (I.E. if C is really I, then so is D.)
I know there's at least one mistake in my reasoning somewhere, I'm just not sure where.
Hi Dopefish1337,
C=Q/(deltaV)
Just looking at Figure 1, I believe you are incorrect in saying that the charges on the capacitors cannot change. These capacitors in series are charged because charges from the "top" plate of capacitor #2 move to the "bottom" plate of capacitor #1, and so the capacitor charge can change without crossing through the capacitor gap itself. (Also, charges move from the "top" of capacitor 1 to the "bottom" of #2.)
I would suggest determining what happens to the total capacitance (of both capacitors) when the dielectric is inserted, and what that means for the charge on each capacitor since they are in series.
Does my reasoning for the questions pertaining to figure two seem correct?
Since in the first figure they're attached to a battery, does that imply they all have the same potential difference, making my answer to a A. S, does not change?
And for B... Sticking in some test values for the capacitences, voltage, and kappa respectively, it seems to show that the total charge on the capcitors decreases when the dielectric is added. So, would that mean the answer to B is D, it'd decrease?
Where does that charge go? Does it get absorbed into the battery?
No, the total potential difference across both capacitors together does not change, but how much is across each one will change.
So before you had the dielectric inserted, each capacitor had a potential difference of V/2 (since they are identical). However, when the dielectric is inserted this is no longer true. The sum of the voltages will still equal the battery voltage V, but they will no longer be identical.
Can you show how you got that the total charge decreases?
To determine the result of Q decreasing, I let C1=C2=1 F, V=1 V, and K=2, since the result of this should result for any given values of the above (outside perhaps a K<1, but those don't exist).
So, without the dielectric, the Ceq would be (1/1+1/1)-1, or 0.5.
Since Ceq=Q/V, with V=1, that leaves as hypothetical charge of 0.5.
With the dielectric, the new Ceq would become (1/1+1/2)-1, or 2/3. Again, with a assumed V of 1, that leaves the resultant Q to increase from 0.5 to 0.67
I believe the first time I must've forgoten to take the reciprocal, leaving my initial Ceq as 2, rather than 1/2.
This 'feels' more right to me, because dielectrics increase capacitence, which has been described as the ability to hold charge to me, so this result seems much better.
I'm a little shakey as to how to approach A though...I feel as there's something very obvious right in front of me, but I can't seem to put my finger on it.
edit: Actually, could I use a similar process and the knowledge that V1+V2=V, to show the potential difference on V2 must decrease? (without wishing to type out the math, getting 1/2 normally, and 1/3 with the dielectric, based on my assumed numbers.)
That's right; so the total charge will increase.
Continue on with your numbers. With those numbers, you found the total charge on the equivalent capacitance (with the dielectric in place) to be Q=2/3. Since the two capacitors are in series, what is the charge on each one of them? Then, once you know the charge on a capacitor and the capacitance, what is the voltage across C2? Compare that to your original voltage across C2; what do you get?
See my edit for what I got - The voltage must decrease.
Thanks a lot by the way.
Before I go off using up my last few tries, do my initial conclusions about the stuff in figure two seem correct, or did I muddle things up there too?
That sounds right to me.
You're welcome!
Your reasoning and your answers look right to me for figure 2. I'm rather suprised they are asking about capacitor 1 when they are changing capacitor 2.
