Understanding Hooke's Law: Sample Problems and Solutions
  • Thread starter Thread starter meikamae
    Hooke's law Law
This discussion focuses on Hooke's Law, which states that the force exerted by a spring is proportional to its displacement from equilibrium, expressed mathematically as F = -kx. Here, F represents the force exerted by the spring, k is the spring constant, and x is the displacement. The conversation includes sample problems illustrating the application of Hooke's Law, such as calculating spring stretch under various forces and determining spring constants. The importance of understanding the distinction between the force exerted on the spring and the force exerted by the spring is emphasized.
  • Understanding of Hooke's Law and its equation F = -kx
  • Familiarity with the concepts of force, displacement, and spring constant
  • Basic knowledge of Newton's laws of motion
  • Ability to solve algebraic equations
  • Practice solving Hooke's Law problems with varying spring constants and forces
  • Explore the concept of harmonic oscillators and their differential equations
  • Learn about energy conservation in spring systems, including potential and kinetic energy
  • Investigate the effects of damping on oscillatory motion in springs
Students studying physics, engineers working with mechanical systems, and anyone interested in understanding the principles of elasticity and spring mechanics.
meikamae
I need a sample problem (and solution, please) for hooke's law to help me understand. I understand the equation, I just don't understand what the variables mean exactly and how the equation works and what each variable stands for.
ok, Hooke's law applies to the idealized case of a spring. The further you stretch the spring, the greater the force opposing the stretching, in other words, it assumes that the force increases linearly with distance.
F = -kx
where k is the spring constant, F is the force generated by the spring, x is the displacement from equilibrium (where F=0). Any basic sample problem will require the equation re-arranged; or substitution of another variable into the two changable variables, x and F; or balance the equation with another force (say, a mass on a spring so that F = mg).
You could also ask to determine the velocity and KE of the spring at any time or displacement of x. Or you could find the general solution to the differential equation of a harmonic oscillator, which is what you've got with a mass on a spring, and find sinusoidal motion in space, decaying exponentially with the damping constant. So it depends on what depth you need.
Hook's law is this: F= kx where F is the force applied to stretch or compress the spring, x is the distance the spring is stretched or compressed and k is the "spring constant". It basically says that the response of a spring is proportional to the force.
Your text may have F= -kx. The difference here is that F now is the force exerted BY the spring rather than the force exerted ON the spring ("equal and opposite").
Here are several "Hook's law" problems.
A spring with spring constant .4 cm/dyne has a force of 40 dynes applied to it (stretching it). How much does the spring stretch?
A force of 600 Newtons will compress a spring 0.5 meters. What is the spring constant of the spring?
A spring has spring constant 0.1 m/Newton. What force is necessary to stretch the spring by 2 meters?
A force of 40 Newtons will stretch a spring 0.1 meter. How far will a force of 80 Newtons stretch it?
  • · Replies 35 ·
  • · Replies 17 ·
