Vectors and medians of a triangle.
  • Thread starter Thread starter wimma
    Triangle Vectors
The discussion focuses on proving that the medians of a triangle intersect at a point two-thirds of the way from each vertex to the opposite side. The triangle is defined as ABC, with midpoints Z, X, and Y for sides AB, BC, and AC respectively. The equations derived are x = c/2 + b/2, y = a/2 + c/2, and z = a/2 + b/2. To establish the intersection point W, a fourth equation is required to relate the segments, confirming that W divides the medians in the ratio of 2:1.
  • Understanding of triangle geometry and properties of medians
  • Familiarity with coordinate geometry and midpoint calculations
  • Knowledge of ratios and segment division in geometry
  • Ability to manipulate algebraic equations
  • Study the properties of medians in triangles using coordinate geometry
  • Learn about the centroid of a triangle and its relation to medians
  • Explore the concept of ratios in geometry, specifically segment division
  • Investigate the use of algebraic methods to prove geometric theorems
Students studying geometry, mathematics educators, and anyone interested in the properties of triangles and their medians.
wimma
Prove that the medians of a triangle (the lines joining the vertices of a triangle to the midpoints of the opposite sides) intersect at a point two thirds of the way from each vertex to the opposite sides.
If you let the triangle be ABC and the midpoint of AB be Z, the midpoint of BC be X and the midpoint of AC be Y, then:
x = c/2 +b/2
y = a/2 + c/2
z = a/2 + b/2
Let the intersection of the medians be W (assuming that they intersect in one point)
Using the above 3 equations, I know that I just need a fourth equation so that I can find a relation between a and x, b and y, and c and z. Then I'd use the formula that if p divides AB in the ratio m:n then p=(na+mb)/(m+n). You'd get two different expressions (eg in terms of a and x in one expression and in terms of b and y in the other expression) which have equal m, n values for 2 different lines. Then you know that since W is the only point lying on both lines, that it must divide them both in the ratio m:n. Similarly do it for the third one and you would know that W is the intersection of all three under the above conditions. I just need to find a fourth equation.
Hi wimma! :smile:
x = c/2 +b/2
y = a/2 + c/2
z = a/2 + b/2
Using the above 3 equations, I know that I just need a fourth equation …
ooh, so complicated! :cry:
Stay on the bandwagon :wink:
use your same method to find the two-thirds point of AX, and you get … ? :smile:
  • · Replies 21 ·
