The change in kinetic energy if distance is constant but angle of force changes.
The discussion centers on calculating the change in kinetic energy when a pulling force is applied at an angle of 38 degrees above the horizontal. Initially, the kinetic energy increases by 47% when the force is applied parallel to the ground. The correct calculation for the change in kinetic energy at an angle reveals a 16% increase, contrary to the incorrect assumption of a 37% increase. The key takeaway is that when calculating work done, the total kinetic energy should be expressed as 1.47 to reflect the increase accurately.
  • Understanding of kinetic energy and its relation to work
  • Familiarity with trigonometric functions, specifically cosine
  • Knowledge of Newton's laws of motion
  • Basic algebra for manipulating equations
  • Study the principles of work-energy theorem in physics
  • Learn about the effects of angle on force application in mechanics
  • Explore advanced topics in kinetic energy calculations
  • Review trigonometric identities and their applications in physics
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to clarify concepts related to kinetic energy and work done by forces at angles.
ha9981
A toboggan is initially moving at a constant velocity along a snowy horizontal surface where friction is negligible. When a pulling force is applied parallel to the ground over a certain distance, the kinetic energy increases by 47%. By what percentage woud the kinetic energy have changed if the pulling force had been at an angle of 38 degrees above the horizontal?
since work is the change in kinetic energy:
w=(Fcos[tex]\theta[/tex] )([tex]\Delta[/tex]d)
0.47 = (Fcos1)(1)
0.47 = F
next
W = (0.47cos38)(1)
= 0.37
Is 37% percent change the correct answer? The one shown in my textbook is 16%, I am pretty sure it wrong unless I am doing this all wrong.
You have the equations right, but used percentage wrong. Stop reading now if you want to figure it out yourself.
Because kinetic energy increases, you should express W = 1.47 instead of W = 0.47. This yields a solution which is >1, which means that the energy really increases. If your solution was the answer, the energy would decrease. Thus, you'll obtain 1.16 as the answer -> 16% increase.
thanks a lot!
just wondering when there is a increase in kinetic energy, the answer i will get will be the previous kinetic energy + the increase. Which would be why it is 1.47.
  • · Replies 16 ·
9K
