Find the area between two curves.
  • Thread starter Thread starter jumbogala
    Area Curves
The problem involves finding the area between the curves defined by the equations y = (7-x)/5, y = +sqrt(x+7), and y = -sqrt(x+7). The original poster attempts to determine the points of intersection and the necessary integrals to calculate the area.
  • Participants discuss the need to identify the correct curves to integrate between the points of intersection. Questions arise regarding how to handle the presence of three curves and which pairs to use for the integrals.
Some participants provide guidance on sketching the curves to visualize the area and suggest that only two curves will bound the area for each integral. The original poster expresses understanding of the bounds for the integrals based on the discussion.
There is mention of three curves, which complicates the selection of bounds for integration. The original poster notes specific intervals for integration based on their findings.
jumbogala
Find the area between the curves y= (7-x)/5, y = +sqrt(x+7) , y = -sqrt(x+7)
I found the points of intersection of the graphs are at x=-7, x=-3 and x=42. So I know I need to do two integrals:
One from -7 to -3, and the other from -3 to 42. But I don't know what exactly to integrate =/
Please help!
Hi jumbogala, you're on the right track - try drawing a picture of you curves
the integral for each section will be the difference of 2 curves (greater y - lesser y valued curve)
use you picture to pick the 2 curves to use for each intergal
Hmm, except that there are three curves so there's actually one on top with 2 underneath... do I have to pick just 2 curves for each integral?
if you sketch you curves, you will see all 3 bound a single area, the area you are trying to find
for any given infintesimal x interval dx, only 2 curves will be acting as the bounds, so use your curve sketch to pick the correct curves for the integral
okay I think I kind of get it...
Between -7 and -3 the area is bounded by +sqrt(x+7) and -sqrt(x+7)
Between -3 and 42 it is bounded by (x-7)/5 and -sqrt(x+7)
Which works, so it must be the right answer. Thank you!
