Calculating the Semimajor Axis of Pasachoff's Orbit
  • Thread starter Thread starter tnutty
    Axis Orbit
The semimajor axis of the asteroid Pasachoff's orbit can be calculated using Kepler's third law, which states that the square of the orbital period (T) is proportional to the cube of the semimajor axis (a). Given that Pasachoff has an orbital period of 1417 days, and using Earth's orbital radius of 1 AU (approximately 1.496 x 10^8 km) and period of 365.25 days, the calculation yields a semimajor axis of approximately 7.429 x 10^8 km. The correct application of Kepler's law involves comparing the ratios of the periods and semimajor axes of both orbits.
  • Understanding of Kepler's laws of planetary motion
  • Familiarity with gravitational constant (G) and mass of the Sun (M)
  • Basic algebra for manipulating equations
  • Knowledge of astronomical units (AU) and their conversions
  • Study Kepler's Third Law in detail, focusing on its mathematical formulation
  • Learn about the gravitational constant (G) and its significance in orbital mechanics
  • Explore the concept of astronomical units (AU) and their application in celestial mechanics
  • Investigate the methods for calculating orbital parameters of other celestial bodies
Astronomy students, astrophysicists, and anyone interested in celestial mechanics and orbital calculations will benefit from this discussion.
tnutty
The asteroid Pasachoff orbits the Sun with a period of 1417 days.
What is the semimajor axis of its orbit? Determine from Kepler's third law, using Earth's orbital radius and period, respectively, as your units of distance and time.
ans : _______ km
T^2 = (4(pi^2) r^3) / GM
1417 days -> 122428800
(122428800)^2 = 4*pi^2 (r^3) / GM
r^3 = (122428800 GM )/ (pi^2*4)
r^3 ~ 4.116 x 10^26
r ~ 7.429 * 10^8 km
I don't know is this right?
I used M = mass of the sun = 1.99*10^30.
G = 6.67 * 10^-11
Where have you used the values for the Earth's orbit in your attempt? This should give you the clue as to what you should be doing. You know that Kepler's law states that the period squared is proportional to the semimajor axis cubed. If you already have the data for one orbit you can find the unknown of another by dividing both proportionalities.
That's not the correct answer, and you didn't use Kepler's third law. Kepler's third law is
[tex]T_{planet}^2 \propto a_{planet}^3[/tex]
or
[tex]\frac{a_{planet}^3}{T_{planet}^2} = \text{constant}[/tex]
Use this in conjunction with the fact that the Earth orbits the Sun in 1 sidereal year at 1 AU.
