Two pm alternators in parallel query
  • Thread starter Thread starter b.shahvir
    Parallel
The discussion revolves around the behavior of two Permanent Magnet (PM) Alternators connected in parallel, specifically focusing on the effects of increasing the driving torque of one alternator on various electrical parameters. The scope includes theoretical considerations related to induced electromotive force (emf), terminal voltage, and practical phasor diagrams, with an emphasis on understanding the internal workings of the alternators under different loading conditions.
  • Shahvir queries how increasing the driving torque of Alt 'A' affects the induced emf 'Ea', the induced emf 'Eb' of Alt 'B', and the terminal voltage 'Vt'.
  • Some participants propose that the loading of the alternators could lead to different phase relationships and impacts on voltage output.
  • One participant mentions that if the load on one alternator increases, the phase of the voltage output will be retarded as torque increases, raising questions about stability and output power generation.
  • Shahvir expresses a desire for a practical phasor diagram that reflects real conditions rather than textbook assumptions.
  • Another participant emphasizes the importance of maintaining phase alignment between the two alternators, suggesting that a cogged belt drive may be necessary to achieve this.
Participants have not reached a consensus on the effects of increasing the driving torque on the alternators, and multiple competing views regarding the loading conditions and phase relationships remain. The discussion is unresolved, with ongoing inquiries into the underlying physics.
There are limitations in the assumptions made about the operation of the alternators, particularly regarding the effects of loading and phase relationships, which have not been fully explored or clarified.
This discussion may be of interest to students, engineers, and hobbyists exploring the dynamics of electrical machines, particularly in the context of parallel operation of alternators and their theoretical implications.
b.shahvir
Hi Guys, :smile:
My query is a bit abstract in nature! But i will be very grateful if someone can provide me with the solution to my query. Here goes;
Consider two Permanent Magnet (PM) Alternators Alt 'A' & Alt 'B' connected in parallel, supplying equal power to a purely 'Resistive' load (unity p.f.). Both the Alternators have equal stator synchronous reactances (stator resistances can be neglected). Please note, they are not connected to the local power grid (infinite bus). Now, if i increase the driving torque of say, Alt 'A', then what changes will occur with respect to the following electrial parameters:-
1) Will magnitude of induced emf 'Ea' of Alt 'A' increase/decrease ? Please explain.
2) Will magnitude of induced emf 'Eb' of Alt 'B' increase/decrease ? Please explain
3) Will magnitude of terminal voltage 'Vt' increase/decrease ? If the magnitude of 'Vt' remains constant or decreases (due to armature reaction), then please explain.
4) Can someone please provide me with a practical phasor diagram for the above query. I am asking for one, since the phasor diagrams in textbooks have lot of assumed conditions & hence do not relate to practical conditions!
Any kind of help will be highly appreciated.
Thanks & Regards,
Shahvir
b.shahvir said:
Hi Guys, :smile:
Thanks & Regards,
Shahvir
Welcome to the PF. What are your thoughts on your questions? What is the context of your looking into this? Are you working on building a project, or is this for school or self study, perhaps?
Thanx Berkeman...How does loading of the 2 PM alternators happen under the conditions, Alt 'A' at 75% loading & Alt 'B' at 25% loading. To increase loading of Alt 'A' to 75%, input torque of Alt 'A' would have to be increased! albiet with a rise in bus frequency.
I basically want to understand the internal happenings in the 2 alternators with respect to the induced EMFs 'Ea', 'Eb' and terminal voltage 'Vt' for the Alt 'A' (75%) - Alt 'B' (25%) loading conditions under steady state conditions.
My query is for academic interest & does not reflect practical requirements.
Thanks & Regards,
Shahvir
Someone please reply to this query too! :frown:
Kind Regards,
Shahvir
This is a difficult project. You cannot change the RPM of either motor (think of adding 59 Hz and 61 Hz-what do you get?), but you can change the phase of either alternator. The two motors have to be kept in the exact phase, which means you need to use a cogged belt drive (like a timing belt) to both. In addition, if the load on one alternator increases, the phase of the voltage output will be retarded as the torque increases, even if the drive belt doesn't slip. If the drive belts are not cogged, I suspect that the stable relative phase of the two alternators will be 180 degrees out, so no output power is generated.
It is much easier to put the two alternators in series and use a step down transformer. But you still need to use a cogged belt.
:smile: Thanx Bob for your reply, but this is not a project. I put this post to gain a deeper understanding of the physics of two PM alternators when connected in parallel. You can say it is a topic of interest for me.
I request you to refer post # 1 of this thread and give a suitable reply to my questions so that i can proceed further with queries if any.
Kind Regards,
Shahvir
  • · Replies 37 ·
9K
