Proving Alternating Groups in Sn: An Index 2 Subgroup
  • Thread starter Thread starter zcdfhn
    Groups
The discussion revolves around proving properties of the alternating group An within the symmetric group Sn, specifically that An is a subgroup of Sn, has index two, and has order n!/2. Participants are seeking clarification on the definition of alternating groups and exploring the necessary conditions for subgroup status.
  • Conceptual clarification, Problem interpretation, Mathematical reasoning
  • The original poster attempts to understand the definition of an alternating group and considers proving subgroup properties through closure under composition and inverses. Other participants provide definitions and suggest necessary subgroup conditions, while also discussing the order of An and its relationship to even and odd permutations.
Some participants have offered clarifications and hints regarding the properties of An, including its definition and the reasoning behind its order. The discussion is ongoing, with various interpretations and approaches being explored without a clear consensus yet.
Participants are working within the constraints of homework guidelines, which may limit the depth of exploration into proofs and require careful consideration of definitions and properties of permutations.
zcdfhn
Let An (the alternating group on n elements) consist of the set of all even permutations in Sn. Prove that An is indeed a subgroup of Sn and that it has index two in Sn and has order n!/2.
First of all, I need clarification on the definition of an alternating group. My book wasn't really good in explaining it.
My attempt at a solution is limited but I was thinking I can prove that An is a subgroup by showing that its elements are closed under composition and it is closed under inverses, but I need to better understand what an alternating group is before I start a proof. Also the order n!/2, I believe has to do with calculating permutations nPn-2 = n!/2! = n!/2.
Thanks in advance.
A_n is simply the set of all even permutations. You know, i assume, what a permutation is right?
So, now you are asked to prove that actually the set of all even permutations, namely A_n, is a subgroup, when the opertaion is composition(multiplication). So all you need to show is that for any two elements of An, call them a,b, then ab is in A_n, that the inverse of every even permutaion is an even permutation, and you are done, siince there is a theorem that guarantees that any set that satisfies these conditions is a subgroup.
thank you so much, it makes sense now
Now the part of proving that the order of An is n!/2 requires more work.
First you probbably know that the order of Sn is n!. however we cannot rightaway conclude that An has n!/2 elements. We first need to show that there are as many even permutations as ther are odd permutations in Sn and then it is clear that the ord of An is n!/2.
Hint:
Let
[tex]S_n=(\alpha_1,\alpha_2,...,\alpha_k,\beta_1,\beta_2,...,\beta_r)[/tex]
Be the set of all permutations where [tex]\alpha_i,\beta_j[/tex] are even and odd permutations respectively.
Now, what you can do is show that [tex]\beta_1\alpha_i[/tex] for i=1,..,k are all odd permutations...it requires a proof by contradiction somewhere along the lines.
Then again, you might want to show that [tex]\beta_1\beta_j[/tex] for j=1,...,r are all even permutations.
What do these two things tell you?
  • · Replies 23 ·
