Designing a DC transmission line
The discussion revolves around designing a DC transmission line intended to transmit 225 MW of electricity over a distance of 185 km with a specified loss of 2.0%. The materials specified for the wires are aluminum, and the operating voltage is 660 kV.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the relevant equations for calculating power loss and resistance, with one participant expressing uncertainty about the role of transformers in the context of a DC transmission line. Questions arise regarding the definition of a transmission line and its design parameters, specifically the wire length and cross-sectional area.
The conversation is ongoing, with some participants providing clarifications about the nature of the problem and the focus on the transmission line itself, rather than transformers. There is an indication that participants are aligning on the key aspects of the design, though no consensus has been reached on all details.
Participants note the absence of information regarding step-down voltages and the limited number of parameters provided in the problem statement, suggesting that the problem may be simpler than initially perceived.
togahockey15
Design a dc transmission line that can transmit 225 MW of electricity 185 km with
only a 2.0% loss. The wires are to be made of aluminum and the voltage is 660 kV.
2. Homework Equations
P= IV = I^2 * R
R= p(L/A)
Power loss = Pf - Pi
Attempt at a solution
I worked through the equations above and found that the cross-sectional area of the wire, if it were a straight wire, would be equal to 1.27*10^-4 square meters. However, I have a bad feeling that this question might be asking for an answer in terms of step-up and step-down transformers, which is a topic I could definitely need some assistance with. Could anyone help explain this to me? My textbook wasn't too helpful... Thanks a lot!
1) It's asking for a DC transmission line, while transformers are AC devices.
2) It does not mention the any step-down voltages.
3) If you're only given four numbers, you're likely to only use equations with four or fewer numbers. Certainly, any realistic problem involving transformers will have many more important numbers than this problem provides.
You're definitely doing the right thing by just considering the I^2 R loss.
- Warren
Hey Warren,
This is probably a dumb question, but what exactly do they mean by transmission line, then?
-Nick
In this case, a piece of wire. :)
- Warren
Transformers are part of an AC system so you don't need to worry about them. You more or less listed the equations you need. Since they've already provided you with a set voltage source, all you really need to consider for this design is the transmission line.
So would the design simply be how long the wire is and what its cross-sectional area should be?
Yes (and some extra letters because you can't have a reply < 4characters)
  • · Replies 20 ·
12K
