Calculating Stress in Beam Under Point Load: Best Methods
  • Context: Undergrad
  • Thread starter Thread starter ladil123
    Beam State Stress
The discussion revolves around methods for calculating stress in a beam subjected to a point load, specifically focusing on the relationship between deflection, shear force, and bending moment. Participants explore various approaches, including the use of equations related to deflection, bending stress, and shear stress.
  • One participant inquires whether stress can be calculated from deflection using shear force or moment, or if a 2D plane strain state is more appropriate.
  • Another participant outlines three necessary equations: for deflection, bending stress as a function of moment, and shear stress as a function of shear, noting that these stresses do not add linearly.
  • There is a contention regarding the nature of shear stress, with one participant asserting it is linear and zero at the mid-plane, while another claims it is parabolic.
  • A participant confirms the formula for bending stress and seeks clarification on calculating shear stress from deflection.
  • One participant suggests that knowing the deflection allows for the application of Hooke's Law to determine stress, but emphasizes the need for a constant value of 'sigma'.
Participants express differing views on the nature of shear stress and its relationship to bending stress, indicating a lack of consensus on these points. The discussion remains unresolved regarding the best method for calculating stress from deflection.
Participants reference various equations and concepts from "Mechanics of Materials," but there are unresolved aspects regarding the definitions and assumptions related to shear and bending stresses.
ladil123
Hello!
If I know the deflection (w) of a beam subjected to a point load in the middle, can I calculate the stress in that beam by calculating the shear force or moment ?
or use a 2d plane strain state ?
What is the best way to do it ?
Thanks
Yes. You need three equations:
deflection of beam as a function of (P,L,E,I)
bending stress of beam as a function of moment.
shear stress of beam as a function of shear.
Then you need to add the two stresses together, but they almost always don't add linearly. Bending stress is varies with the height, y, within the section; ie: high at both top and bottom fibers, and zero at the mid section. Shear stress is parabolic, with its maximum at the mid section. A bit of reading will reveal what shear stress engineers usually use at the extreme fibers (it is not zero).
This is all in most books on "Mechanics of Materials".
Shear stress is linear and is zero at the mid plane. Bending stress is parabolic.
You had them backwards
Ok.
So the bending stress sigma_B = M_max *Z/I , right? I=moment of inertia.
What about the stress due to shear then? With the equation for deflection I could integrate and get the shear force, but how do I get the shear stress ?
I guess I wasn't clear. I was referring to the transverse stress level within a SECTION of the beam, and not referring along its length.
What you said is true but for longitudinal stress along the length.
I think I didn't get the question.
Yeah if you know the deflection, you can apply hooks law and figure out the stress.
But for that you also need to know 'sigma'; the constant.
  • · Replies 25 ·
  • · Replies 52 ·
