Rate of Change: Distance Between Moving Point and Fixed Point
The problem involves a point P moving along the line defined by the equation y=(1/2)x and seeks to determine the rate of change of the distance between this point and a fixed point Q (0,11) as x decreases at a specific rate. The original poster attempts to apply the distance formula and implicit differentiation to find the solution.
  • Mathematical reasoning, Assumption checking
  • Participants discuss the application of the distance formula and the chain rule in the context of related rates. There are questions about the correctness of the differentiation steps and the treatment of dy/dt, with some participants suggesting the need to derive y in terms of x.
Some participants have provided guidance on the differentiation process and pointed out potential errors in the original poster's calculations. There is an ongoing exploration of how to properly apply the chain rule and the implications of assuming values for derivatives that are not explicitly given.
Participants note the lack of information regarding dy/dt and the implications this has on the differentiation process. There is also mention of the frustration experienced by the original poster in arriving at the correct answer.
Emethyst
A point P (x,y) is moving along the line y=(1/2)x. If x is decreasing at the rate of 3units/s, at wha rate is the distance between P and the fixed point Q (0,11) changing at the instant when P is at (6,3)?
Implicit differentation
From what I can see for this question, the distance formula needs to be used. That is what I did, I plugged in the point (x,y) and (0,11) into the distance formula and found the derivative, then plugged in (6,3) for x and y and -3 for dx/dt. The answer I got was -2.6, however, this is not the right answer as it is supposed to be -0.6. This question seems easy yet it is frustrating me, if anyone could be help it would be greatly appreciated, thank you.
Your method looks fine; why don't you show me your work and I can see where you are going wrong...
Point 1=(x,y)
Point 2=(0,11)
s=((x-0)^2+(y-11)^2)^1/2
s=(x^2+(y-11)^2)^1/2
s=(1/2)(x^2+(y-11)^2)^-1/2(2x(dx/dt)+2(y-11)(1))
s=(1/2)(6^2+(3-11)^2)^-1/2(2(6)(-3)+2(3-11))
s=-(1/2)(100)^-1/2(-52)
s=-2.6
I think I have done the chain rule right, as I have attempted this question a few times, all with the same results.
Emethyst said:
Point 1=(x,y)
Point 2=(0,11)
so far so good, but...
This line makes no sense...even if you meant to say
ds/dt=(1/2)(x^2+(y-11)^2)^-1/2(2x(dx/dt)+2(y-11)(1)) (as opposed to s=...)
you would still be incorrect:
[tex]\frac{d}{dt}[x^2+(y-11)^2]\neq(2x(\frac{dx}{dt})+2(y-11)(1))[/tex]
because
[tex]\frac{dy}{dt}=\frac{d}{dt}\left(\frac{x}{2}\right)\neq1[/tex]
Hmm so that is where I am going wrong? How would I properly go about fixing that line then? Because from what I was taught, in adding situations you apply the derivative to both terms:
(d/dt)(x^2 +(y-11)^2)
(d/dt)(x^2)+(d/dt)((y-11)^2)
(2x)(dx/dt)+2(y-11)((d/dt)(y-11))
(2x)(dx/dt)+2(y-11)(1)
That is how I came about that, and because it is the chain rule from ds/dt=(1/2)(x^2+(y-11)^2)^-1/2, I multiplied (2x)(dx/dt)+2(y-11)(1) by it.
up to here you are correct, but...
where is the (1) coming from...shouldn't that be (2x)(dx/dt)+2(y-11)(dy/dt)?
I used 1 because no information is given for dy/dt and the question is not asking for it, unless I am required to take the derivative of the equation given and plug it in for dy/dt? I think the light buld may have clicked :-p
Nope, even if the derivative of y=(1/2)x is taken and used it simply results in an answer of -2.2 instead of -2.6.
So whenever you have any equation with a variable and you aren't told what that variable is equal to; you automatically just assume it is equal to one?!:confused:
Of course, how else are you supposed to find dy/dt?
I get -0.6 when I do it, so you must be making a mistake...show me the calculations
No, I just overlooked it in this question by accident, spent too much time on the other questions, it drained my mind :-p
And I just got -0.6 for my answer. I forgot to include dx/dt in the derivative, for I simply took it to be dy/dt=1/2 instead of dy/dt=(1/2)(dx/dt); I fixed that little error and came up with the right answer at last. Thanks for all that help gabbagabbahey, I don't know if I have spotted my mistakes if it was not for your assistance :smile:
  • · Replies 23 ·
