Two wavelengths, max/min at same angle
  • Thread starter Thread starter cashmoney805
    Angle Wavelengths
The problem involves light passing through two slits and questions whether there exists an angle where light of two different wavelengths produces a maximum for one and a minimum for the other. The subject area pertains to wave optics and interference patterns.
  • Exploratory, Assumption checking
  • The original poster attempts to relate the conditions for maxima and minima using the provided equations, questioning the relationship between the integer orders (m values) for the two wavelengths. Some participants question the physical setup, specifically the distance between the slits.
The discussion is ongoing, with participants clarifying the slit separation and confirming that the m values can differ but must be integers. There is no consensus yet on the implications of the corrected slit distance.
There was initial confusion regarding the distance between the slits, which was corrected from 40 mm to 40 nm, and further questioned as possibly being 40 μm. This uncertainty may affect the interpretation of the problem.
cashmoney805
Light goes through two slits 40 mm apart. Does an angle exist at which light of wavelength 440nm has a maximum and light of wavelength 660nm has a minimum?
dsin[tex]\theta[/tex]=m[tex]\lambda[/tex]1 = maximum
dsin[tex]\theta[/tex]=(m+ 1/2)[tex]\lambda[/tex]2 = minimum
I solved for sin[tex]\theta[/tex] in each case, so I got:
m[tex]\lambda[/tex]1 = (m+ 1/2)[tex]\lambda[/tex]2
[tex]\lambda[/tex]1 = 660nm
[tex]\lambda[/tex]=440 nm
Now I'm stuck. Both Ms do not have to be the same, right? So do I have to solve for one of the Ms and stick it into an equation I listed in part 2 above? If so, that's a crazy calculation. Thanks!
Correct, the m's can be different. But they must both be integers.
Are the slits really 40 mm apart? That's pretty far for an optical double slit setup.
They're actually 40 nm apart, sorry.
Are you sure it's not 40 μm?
ah yes you're right
14K
