Calculating Norm of a Vector with Two Vectors
  • Thread starter Thread starter physguy09
    Norm Vector
The discussion revolves around calculating the norm of a vector defined as the difference between two vectors, specifically in the context of momentum transfer. The original poster expresses uncertainty about the calculation, given that both vectors have equal magnitudes.
  • Participants explore the relationship between the vectors using the inner product and question the assumptions regarding their orthogonality. There are attempts to derive the norm through various expressions, with some participants questioning the validity of their reasoning.
The conversation is ongoing, with participants providing guidance on how to approach the problem mathematically. There is a mix of interpretations regarding the expressions used, and some clarification is sought on specific terms. The original poster has submitted their assignment but continues to seek understanding.
Participants note that the problem does not specify whether the vectors are orthogonal, which affects the calculations. There is also mention of a known value for the vectors' magnitudes, which is relevant to the discussion.
physguy09
Ok, so I have no idea how to take the norm of a vector composed of two vectors. I have
[tex]\vec{q}[/tex]=[tex]\vec{pi}[/tex] - [tex]\vec{pf}[/tex]we are given:
|[tex]\vec{pi}[/tex]|=|[tex]\vec{pf}[/tex]|=|[tex]\vec{p}[/tex]|
so i know that
|[tex]\vec{q}[/tex]| [tex]\neq[/tex] 0, that would be too easy, and it doesn't make sense.
now, is the following right? it just doesn't seem to be
|[tex]\vec{q}[/tex]|=[tex]\sqrt{2}[/tex]*|[tex]\vec{p}[/tex]|
You can try working it out explicitly through the inner product.
Note that
[tex]|\vec q|^2 = \vec q \cdot \vec q[/tex]
so
[tex](\vec p_i - \vec p_f) \cdot (\vec p_i - \vec p_f) = \ldots?[/tex]
ok so that gets me |[tex]\vec{q}[/tex]|=[tex]\sqrt{|\vec{p_{i}^2}|+|\vec{p_{f}^2}|}[/tex],
would that then be [tex]\sqrt{2}[/tex]p?
No, it doesn't get you that. Not unless [itex]p_i[/itex] is orthogonal to [itex]p_f[/itex], and the problem statement (as you gave it) doesn't say that.
Please stop guessing and work it out properly.
[tex] (\vec p_i - \vec p_f) \cdot (\vec p_i - \vec p_f) =<br /> (\vec p_i - \vec p_f) \cdot \vec p_i - (\vec p_i - \vec p_f) \cdot \vec p_f = <br /> \vec p_i \cdot \vec p_i + \cdots[/tex]
not guessing, just not typing it out entirely. i wrongly assumed pi and pf were orthogonal, but i was trying to make use of the fact that
|p|=|pi|= |pf|.
i know |q|=[tex]\sqrt{\vec{p_{i}^2} + \vec{p_{f}^2 }-2*\vec{p_i}*\vec{p_f}}[/tex]
but i know |p|=|pi|= |pf|, so |p|[tex]^2[/tex] must equal |p|2=|pi|2 = |pf|2, hence, possibly with faulty reasoning,
|q|=[tex]\sqrt{2*p^2-2*\vec{p_i}*\vec{p_f}}[/tex]
You are getting closer, it's just not entirely clear to me what
[itex]2 * \vec p_i * \vec p_f[/itex]
means. In particular, what do the asterisks mean?
After clearing that up, can you write that expression in terms of p as well?
apologies, I began to get sloppy, as I'm still trying to get used to Latex, it should be
|q|=[tex]\sqrt{2 p^2-2 \vec{p_i}\cdot\vec{p_f}}[/tex]. I would not know how to write it out in terms of p, and it might be useless in this case, as we are supposed to plug in a known value for p. [tex]\vec{q}[/tex] was mainly momentum transfer, and we were given that for this case [tex]\vec{q} = \vec{p_i} - \vec{p_f}[/tex]. i already turned in the assignment, just wanted to reach the answer for the sake of learning.
Yes, at first you will work more slowly when you have to do the math and learn how to write it out in [itex]\LaTeX[/itex] - compliments for doing it anyway :)
What I was hinting at was to define [itex]\theta[/itex] as the angle between the ingoing and outgoing momentum, and writing
[tex]\vec p_i \cdot \vec p_f = |\vec p_i| |\vec p_f| \cos\theta = 2 |\vec p| \cos\theta[/tex].
Then you can take [itex]\sqrt{2}p[/itex] outside the square root, if you want to write it more beautifully.
